Mounting vise to metal cabinet?
erty67
https://goo.io/KKQVMl
Anyone ever mount a vise (or something similar) to a metal cabinet like this? I have a 5" craftsman vise that I picked up a while back and it's been on the shelf ever since. I picked this cabinet up today (for $40) and thought it'd make a great new home for my old vise. Trouble is the top seems to be made of metal and is not a thick as I expected. I was originally going to build a bench with 3/4" plywood on top. It seems really sturdy though. I just don't know how good it'll handle the vise loaded. I don't plan on working on anything extremely heavy. This is more of a "hobby station" than anything. Any thoughts?
ken w.
Western New York
You could put some large flat washers on the bottom side to spread the load out.I don't see much of a problem unless your pounding U-joints apart.
E
erty67
yea, I was thinking about that or there is room for me to put plywood under the vise area to help spread the load. I'm mostly looking just to have it when I need an extra set of hands. I can't say I won't be doing any hammering, but I wouldn't overkill. I mostly want it to hold metal when I need to drill it, cut it, etc.
Zeke
I have vises for holding things and ones for heavy work. It's all in what you normally do. If you put a piece of pipe in the vise on the cabinet will you be able to use a hacksaw w/o the cabinet wobbling? That's when I go to the big dog. But I use my little Shop King all the time. It still looks like this after a year and a half.
Higgins
Shepheardsville, KY
How about removing the inside shelf, and install a piece of 3/4" plywood inside the top of the cabinet. That will stiffen the metal cabinet top. Then just bolt the vice to the top!
AL
Boomer343
Get a piece of 3/4 ply the width of the wall studs where you want to mount the vice and cut it to the depth of the cabinet. Get a 2 x 4 the width of the wall studs.
Mount the vise to the plywood. Mount the 2 x 4 to the plywood. Screw the 2 x 4 to the wall studs.
Cabinet then only has to support the vise and take downward pressure. No rock and roll when sawing etc.
