I would like to install some metal wall cabinets (four sets in total) lengthwise across the back wall in the garage, however - I have some questions due to inexperience
I am curious about the proper way to mount them. Their instructions are of course, straight-forward in telling you to locate the studs & use the supplied lag-bolts (4 total, one for each corner of the cabinet).
My studs are located 24" apart on centre - whilst the cabinets are 26" wide in total. Their pre-existing perforated strips go to a maximum of 24" apart, which is fine.
So installing ONE cabinet, I could ensure it is mounted to TWO studs, using all 4 lag-bolts. However, every cabinet thereafter would not align such that they could be mounted to two studs. I would only be able to mount it to one stud with two lag-bolts.
What is reccommended in this kind of scenario, to achieve four sets side-by-side whilst ensuring it is safely mounted to the wall?
