NWOhioChevyGuy
OK, I've posted on here a couple times about the attached garage I plan to build onto my 1800's farm house and hopefully in the spring the project will happen / begin.
However where that garage will stand is an old 1 car garage that was at one time a carraige barn. What I would like to do is move it back on the property to be refitted for my daughters and their animals. (Rabbits & Goats, etc.)
I have seen this done once before, yet the garage was in a little better shape, at my parents house. They bought a 2 car garage from the neighbors and moved it down the road to their house about 1/8 mile. I was probably 6 or 7 when this was done so I don't remember much besides them pouring the pad and the pictures of the move.
I see it going something like this:
A) Brace Garage - Diagonally with 2x lumber & maybe cables
B) Run double (sandwich) of 2x8 down the sides of garage (inside and outside) for lifting the structure on I beams.
C) Cut 2 holes on each side just under these 2x8's to slide I beams
D) Seperate garage from breezeway
E) Seperate garage from foundation (should be easy as it is crumbling)
F) Insert I beams through holes cut above.
G) Using bottle jacks lift up the garage to height where trailer / running gear can be moved under.
H) Roll trailer / running gear under
I) Set garage onto trailer / running gear
J) Roll to new location and revearse process.
New location will be a floating pad and the walls will be prepped by cutting off bottoms and fastening a new PTL plate which will anchor it to the pad.
The garage will then be resided, door wall rebuilt to have a barn style door, and reroofed.
Input on the process would be helpfull.
Thanks,
Keith
Thanks,
Keith
