Moving metal carport/building
niL
Long story short, my enclosed carport was placed on the property line of my neighbor. I'm about 3 feet over the line, and was wondering if moving my building 10 feet to the left is possible? My concrete guy said there will be no problem pouring into the slab to extend it. I I would like to keep it intact because it's already spray foamed. Is this something that can be easily done or should I just fork over 15k to my neighbor for 20ft of their property.
CamMark
Palmetto State
Assuming 15k is a fair value and you have the funding it might make sense from a long term financial standpoint. In theory your lot would then be worth that extra 15k and have potential to appreciate.
Moving the building probably isn't such a big deal technically, but there is some risk and cost- either your time if DIY or contractor fees if not. There's the material cost of the extra concrete too.
Was this missed at the survey or was that skipped?
readhead
Durango, Co.
Once you brace the base rails I have seen videos of buildings being moved on skates. The building I saw was braced, jacked onto the skates, moved 12’ and bolted back down in four hours.
N
niL
Wow that’s quick! The survey was based off pins driven when the home was built. One pin was covered in gravel and where they “guessed” it was off by a few feet. When connecting the pins the corner of the building sits on my neighbors lot. Luckily I do have the option to purchase the additional land from my neighbor.. I was just wondering if it was feasible to move it over instead.
isb cornbinder
Kudos to not giving the OP too much ****. I know a local home builder that built a house on the wrong lot. :)
My dead friend was a carpenter. He was renovating a home on the West Side of Vancouver. He always took his tools home at the end of every day. On Monday he arrived early and the house was gone. HIs first thought was, maybe I am on the wrong avenue.
Another house, across the street was to be demolished and it was still there. I do not know what the final settlement was.
jack stand
Lakes Region Maine
If you don't feel comfortable moving the building yourself, consider the additional concrete costs and whatever you pay someone to move it against the neighbors $15k price.
Then make your decision.
Depending on your plans and the lots layout, additional land might be the best move.
nadogail
Coronado, CA
I have helped a neighbor move a shed he built too close to the fence line. The HOA objected to it’s placement.
The shed builder rounded up his able bodied neighbors and we literally picked up the shed, carried it three feet and set it where it was wanted.
dougf
Missouri
I vote to purchase the extra real estate for the 15k and be done with it... You'll have a slightly bigger lot, and you dont have to mess with the issues that could occur when moving the already spray foamed building.
FL Guy
Is $15k reasonable for your town/area? If the neighbor is trying to **** you because you are in need, I’d buy the 15’ and store a bunch of unsightly sh*t on that side of your garage 😂
KenC
oklahoma
Sure it can be moved. And IMO, not with much difficulty. Pour the extension and let it cure for at least a week. Unbolt the building from the slab. Brace the door openings well. I suggest some of the same tubing used in the frame. weld to the frame, good tacks are enough. These can be cut loose with a grinder after moving and the weld damage coated with 'cold galvanizing'.
Create lifting 'ledges' or front to back wall connection on the interior walls. Either weld more of the tubing to the uprights or bolt 2x lumber in place to allow jacking.
buy or borrow some cheap bottle jacks. You only need to raise it a few inches. insert pipe pieces under the bottom of the walls. lower building onto the pipe. Pull 3 feet with come-a-longs. Raise with jacks, remove pipe. Drill anchor holes. Insert anchors, remove bracing etc.
calculate your costs vs the cost of the land. Your decision.
tyyost
Tunkhannock, PA
If you move the building will leaving the slab be an issue with the neighbor? Since you have all the concrete work done it may make sense to purchase the property over moving the structure. If you didn’t have the driveway done I‘d be in the brace it and move it camp but as others have said the 15k seems reasonable given the circumstances.
Chaznsc
SC
I’d buy the land if your neighbor is willing. Moving is a risky venture imo. Make sure to buy enough to satisfy any setbacks required by town and or subdivision or god for bid HOA.
johnre
Portland, OR
If the neighbor is willing to sell you the land, would he also be willing to swap equivalent square footage with you at some other part of the common property line? Perhaps you could offer to cover the recording costs, and that would be your only cash outlay.
dougf
Missouri
Yeah, an update would be nice though! I get curious about the outcome of a lot of these threads.
