Moving outlets up a wall
chrislehr
Portland, OR
I know how to do this, but a friend told me moving them from default height would put me out of code. Not planning on selling anytime soon, but figured I would ask - would you leave the lower outlet and just extend the outlet to above a workbench height, or plan on removing and filling the lower outlet hole?
CoopVA
Virginia
There is no code requirement for outlet height that I am aware of. I've put outlets in base boards and in ceilings...
blatterjr
Code requirements are by jurisdiction... since you're in the garage, they typically don't apply to location, only that they exists on specific walls. That said, I'd leave the lower box.
coleman10
Fort Lauderdale, FL
The outlet can be at any height, but if you do decide to do this, any splices/connections need to be accessible. If you move the receptacle up by splicing into the original box, don't wall over the original box and connections, but rather put a blank cover over it. If there is ever a problem with a connection in there, you'll need the access. Either that, or make a home run back to your breaker panel, thereby eliminating any splicing.
Norcal
Just another quote from the "Urban Legend Code" by a friend. :D
The only place that receptacle spacing is specified is in a dwelling, and any receptacle over 5 1/2 feet from the floor do not count as meeting the requirements, for a garage only one is required so as long as the one required receptacle is not more then 5 1/2' from the floor it does not matter about the rest, but "workbench height" should be below that.
Stevie-Ray
Michigan's Sunrise Side
^Yeah, what he said.
