Moving Water Heater in Garage
bromley
north myrle beach
I recently mover my water heater across the garage,approximately 50 feet. Now it takes a lot longer to get hot water through the house especially 2nd floor. If I go with a tankless system would that solve my problem? Also I don't have gas in the house. It would have to be an electric system. Any info would be a great help. Thank You
LS6 Tommy
Northern NJ
50' shouldn't make that much difference in delivery time. I'm not sure what other issues may be causing the delay.
Tommy
pattenp
Virginia - USA
If the tankless is placed close to the points of use, then yes. If placed where the current tank is, no.
sberry
Brethren, Michigan
50 ft would make a huge difference especially with 3/4 pipe and low flow fixtures. Put another small electric in series near point of use, this will still be energy greedy for every hand wash. Changing to a smaller hot pipe would help some, only place its a bit of a bottleneck is tub filling.
bamawildcat
Tankless won't help in that situation. Recirculating pumps is what you should be looking at.
GMCGarage
50' is about 1.2 gallons in the pipe. Avg faucet is about 2.2 gallons per min. You are wasting 30 seconds of water waiting for hot water.
Showkey
"MEMBER EMERITUS"
Wausau WI
cuz Luke warm might not enough Plus another 30-120 seconds to actually get HOT water ...........
glentre
Gloucester, Virginia
Run a separate pipe teed off of the heater hot water outlet and tee it into the hot water riser where the heater was originally located. Then, insulate both lines. With no circulating pump, there will be a thermo siphon action that will keep both lines hot at all times and give you hot water where the heater used to be located, giving you the same performance as you had prior to moving the heater.
Glen
fourjeepin
Atlanta, GA
I looked at electric tankless water heating and it requires lots and lots of power. I would bet more than is available without upgrading the electrical service.
hotrod1968
oregon
Recirculating pump... my house is 4500 square feet with water heater in garage... hot water at all facets on demand..
glentre
For those suggesting circulating pumps, how would a pump be installed when the op only has one hot line coming from the heater? Not being critical, just curious. If you install a second parallel line, it will thermo siphon and both pipes will be hot without needing a pump.
Glen
BigGarage
Just south of Detroit, MI.
I recently moved my water heater across the garage,approximately 50 feet. Now it takes a lot longer to get hot water through the house especially 2nd floor. If I go with a tankless system would that solve my problem? Also I don't have gas in the house. It would have to be an electric system. Any info would be a great help. Thank You
In 2015 I remodeled my 2nd floor 1/2 bath and went with a tankless heater because I figured by the time hot water got up there I'd be done washing my hands. I bought a Rheem and I didn't study enough about it. It required a 240 volt supply so I had to run a new line up there from the main panel but other than that and the fact that I had never soldered a copper joint before it came together well. It cost $185.50 with tax. The box says max flow is 3 gals. per minute if needed. I don't know as I've never checked.
It's mounted in a cubbyhole behind the bathroom and so is only a couple of feet from the sink. It gets warm in 4-5 seconds and reaches the max temp I have it set at in 9-10 seconds. I'd recommend it to anyone who is looking for a tankless unit.
Dennis
LS6 Tommy
Northern NJ
Glen
There are systems on the market that have a regulating valve that uses the cold water line as a return on a call for hot water. No need to run additional return lines.
http://www.tacocomfort.com/products/systems/instant_hot_water/hotlink/index.html
Tommy
glentre
LS6 Tommy,
Thanks for the input on the Taco recirculating system. I did not know about this option. Did some reading on it and it's an interesting concept but any one installing it would be wise to evaluate performance issues plus initial and operating costs vs more simplified solutions.
Glen
