Mower blade maintenance in remote shop
Lx460
Central Florida, USA
Weighing the options of how to allow for blade removals for sharpening. Need to be done at least twice a week. Have a small conex container with 4 mowers in a satellite branch. Should I set them up with a small 110V compressor and impact gun or just get a Milwaukee fuel 18v impact?
Thoughts?
zkling
A breaker bar, some heavy welding gloves and a hunk of 2x4.
L
Lx460
My thoughts too, but after working outside in 90 degrees plus with 100% humidity for 10+ hours a day, you have to have a little sympathy.
Just a little.
Besides that, I might actually end up having to do it once in a while.
zkling
What kind of mowers are we talking here? Single blade push mowers or twin+ blade riders? How are they sharpening?
How about an electric impact? Unless you are needing air for tires and such. I'd just be real careful of people using the impact to put the bolts back in. I've seen a hand full of crank ends destroyed because of that.
justtools
Just a little.
No you dont. But if you insist the do have very good electric impacts.
rice rocket
Small compressor + impact is much less likely to grow legs and walk off than a cordless impact.
kd3pc
Northern Neck
the bigger issue is to how to "safely" get the blades off, without a ramp or something to raise the deck high enough to get a fuel or impact and the correctly sized socket to the hub bolts.
IIRC, the exMark is about an inch or 27mm bolt...I usually get them in the shop when someone has used a pipe wrench with two feet of kendorf or a pipe on the handle....or buzzed the corners off with an impact.
Now you need some tools...
best of luck. BTW, we ended up putting the machines on a 45 day maintenance plan where we just took blades and bolts from the shop out to the machine, replaced them and brought the "dull" blades and wonked up bolts back to the shop for sharpening. It turned out to be much cheaper time and effort, to have one guy responsible to NOT mess up three bolts and be down a day (or more) waiting on a part or a fix. HE kept the correct tools, washers and bolts and blades.
SARG
Northeast
Sharpening twice a week ??????
Seems like you're cutting something other than grass.
Farmall 1066
Suburban Rockford, NE
As much as I hate cordless angle grinders, this might be the place.
If it were mine, I'd get a cheap-assed 110v generator, grinder and impact.
Bargain shopping you could get all for 100-200, or new HF for not much more.
Quality of equipment would need to be balanced against likelihood of theft, I guess.
L
Lx460
This thread is turning into a classic example of it pays to give the total picture from the get go.
It's just shop talk, not rocket science. Everything doesn't have to be 100% perfect to bring it up for discussion. I was just throwing it out there for ideas and I got a lot of good ones.
L
Lx460
Florida is all sand. Nothing dulls blades quicker than sand. Twice is on a heavy week but at least once. Maybe overkill but makes for a much better cut.
Charles (in GA)
50 mi south of Atlanta
Compressor and impact. Much more useful. You could rig a beam across the inside of the container, just inside the door, with a small trolley and come along or chain hoist to lift the front end. If your mechanical people are reasonably reliable they won't overload it or kill themselves. Couple of jackstands for safety.
NC-Shaun
Sharpen them on the equipment. Proper jack for the equipment and an angle grinder....Thats how I did my lawn mower when i was reclaiming 8 acres of land.
