Mower deck crack repair
Ben Buck
S. W. Ohio
Small crack on my mower deck.
Have been advised by several non reputable sources to drill a small hole near the top of the crack and run a bead, and grind it down & paint.
Is the hole to be drilled at the crack start , or above it, and is it necessary to run a bead underneath?
Any advice would be appreciated. I have a Handler 140 & gasE758EECC-5E3C-49E4-B7E8-B4E5656EE6A9.jpeg2CCE272B-F1F0-44D2-A9E9-4617D5871F64.jpeg
msharley
Central Pennsylvania
Me?
Would run a bead on it.
Quick grind.
Fit up a small piece of flat bar...and series tack it around...about a 1/2" to 3/4" overlap...
Will out last the deck..
Jswain
Calgary, AB
Probably fairly thin sheet metal so even your 140 should penetrate fully to do a one sided weld.
I wouldn't even worry about drilling, clean the paint and rust up & weld it hot. Start with 1 tack on the outside edge, then weld it from the interior of the crack towards the edge should help from burning through at the end.
NYBODYMAN
NY
Definitely drill a hole at the end of the crack to prevent it from spreading further. Then "V" out the entire crack line a bit, sand/grind paint and rust away to get good clean metal, and stitch weld it. I would then dress the weld if desired and put some sort of paint on top of it to prevent rusting.
428PI
Peabody, KS
I wouldn't worry about it. That crack will end at the rusted out hole. You're good to go.
cpttuna
napoleon ohio
I would a pop rivet a piece of ss underneath. grind the crack and weld ensuring to get all 3 pieces welded. Drill out the pop rivets and weld the holes getting the metal underneath at the same time.
