Mower maintenance injury -- graphic
jives
Central NY
In brief. . . last mow of the season with the zero turn and follow up with a good cleaning, oil change, grease, etc. Finished mowing, was hosing down the deck, had the seat pitched forward, reached under to grab clumps of grass. Bumped the seat, got my hand caught in the hinge pivot point as the seat slammed down. 10 stitches later, but as you can see in the pic, the tendons still intact. Fingers still numb, got some bruising of the nerve.
Shiftless
East Bay SFO
Ouch indeed.
Maybe next time use a prop of some kind on the seat. Or don’t reach in at all and blow it out with compressed air,
Junkdrawer Dog
LV NV
Yikes! But it's always the thing we least expect that bites us. With mowers, we take extra care regarding rotating blades, belts and sheaves, or even hot exhaust pipes, only to get bit by the seat! Best wishes on your recovery and that'll never happen to you again I'm sure.
joel63
Central FL
Here's to a speedy and pain free as possible recovery.
driftpin
Keep it clean! It's easy for that to become septic. If it becomes swollen, reddened and inflamed, tender to the touch, go back to the hospital.
On fire-rescue, we responded to a single family residence, report of a lawn-mowing accident. We run with three crew on the ALS (advanced life support) ambulance. There was a FNG with us. I was giving him some 'when we get there' instructions, mainly involving what to do if it was an arterial bleed, PPE, and that we wanted to wrap the victim up ASAP, and get underway to the trauma facility. We would call while underway to the trauma facility to advise them, and it would be a short transport time, typically less than 10 minutes.
When we got there, the mower operator was sitting on the ground. One foot had gone under the deck. The sneaker was saturated with blood on the front half. I was in my PPE, and removed the sneaker, I had a thick multi trauma dressing and a couple wide rolls of Kling. When I peeled off the sock, the amputation of some of the toes was evident. I wrapped the foot with the multi trauma dressing, the Kling, and he was placed on the gurney. We got him into the transport, and I asked the FNG to grab the sneaker. "Where do you think the toes are?" I asked. He turned the sneaker upside down and shook it, and they fell onto the grass, right onto a bull ant colony anthill.
"OK, let's put those onto a sterile 4X4 bed in a kidney basin, and please wash-off the ants first." The FNG did as he was told, and he got 'baptized' successfully. He turned into a great firefighter/paramedic and a good friend, and now we're both retired. I've had FNG's come back to the station after a bad call, and quit. He proved his worth.
coldh2o
Ontario, Canada
What's an FNG?
mervyn
Northeast Missouri
Dang it man. Heal up quick.
Messed up the back of my right hand in a car accident aboot 12 years ago. Tendons were severed. Took a year before I could make a closed fist. I've got pics somewhere. Here it is. That's after tge cast came off. 08E47FE0-9F2F-4185-9194-D06E8667B1CE.png
PoorUB
Fargo, ND
I have had my share of hand injuries. I remember at work cutting the palm of my hand near the wrist deep enough that I could pull the wound open with my fingers and wiggle my thumb and watch the muscle move. I thought it was kind of cool! I walked into my boss and told him I needed to go get stitches and he asked, "Are you sure? I stuck my hand in his line of site, with the wound pulled open and wiggled my thumb to get the full effect. I thought he was going to lose his lunch! He drove me in.
A year or so later another injury and I told the boss I needed to go in. He asked again if I was certain, and I asked if he wanted to see? He said, "No, lets go!"
Another time, different job I cut the back on my hand right above the knuckle of my little finger. Right away I noticed the finger curled up and It would not straighten without help. I knew I cut the tendon. I went in and got it sewed up, no issues after that except when I made a fist my little finger would not fully close.
About a year later I was rebuilding an engine and torquing main bearing caps. I was pulling hard on the torque wrench and felt something "pop" in my hand. At first I thought, "****, I tore the tendon for my finger!" I set down the wrench and looked over my hand and carefully worked the fingers back and forth. I had full movement on my little finger. Apparently I tore lose some scar tissue. That was maybe 25 years ago and it has worked fine ever since.
southalabama
Brewton AL
I’ve got my share of scars. I feel each of your pain.
To quote John Wayne from Big Jake when asked if the sight of blood bothered him answered,
Only my own.
Bill T
Easley,S.C.
I work at a large power plant (2k+ employees). I have had 2 co-workers killed on zero turns. Both were trapped under mowers that had turned over in ditches.
gunguy
Currituck Co. NC
I had a landscaper over last week to do some work for me. He shows up with a bandage and brace on his left wrist and forearm. He tells me at another job he was in an akward position while cutting a zip tie with box cutter and cut the fleshy part of his hand just below the thumb requiring some stitches.
I asked him if he had that personel alarm go off in his head just before cutting himself. Yep, he says. We both chuckled and said when that alarm goes off, listen to it. STOP and figure out a better/safer way to do what you want to do.
Wishing you a speedy and uneventful recovery.
Jim
NUTTSGT
Northern Central Ohio
Keep it clean while it's healing.
I'm surprised you didn't get a few more stitches.
As a side note, I have never figured out how someone wears nitrile gloves that loose.
KEH
Lots of lawnmower injuries. A former student had a young son almost get killed in lawn mower accident, broke jaw. Years later I had that son, he was ok but had serious jaw scars.
BIL, a WWII Navy veteran, lost a toe to a lawn mower. He lived to 99.
I don't fix anything on a lawn mower unless the engine is off and I am on the ground. Same with farm machinery.
KEH
