mower oil change reminder
TAB57
kirkville ny
Hello Have a 2754GLS Husqvarna mower and just noticed that the hour meter was flashing to do sixth oil change have done that and only have been running it to roll the lawn and today to collect the branches that fell. The battery was disconnected over the winter and just hooked it up how do I reset this does anyone now? Thank you for you time and answers.
LB-1911
Northwestern Il.
Pg 14 of your Owner's Manual *
SERVICE REMINDER/HOUR METER
Service reminder shows the total number of hours the engine
has run and flashes to indicate that the engine or mower
needs servicing. When service is required, the service
reminder will flash for two hours.
To service engine and
mower, see the Maintenance section of this manual.
NOTE: Service reminder runs when the ignition key is in any position but "STOP". For accurate reading, be sure
key remains in the "STOP" position when engine is not
running.
*http://www.husqvarna.com/ddoc/huso/huso2008_usen/huso2008_usen_o0802078_.pdf
jallyn
Fort Wayne, Indiana
or go low tech... at the end of mowing season I run the gas tank dry then change the oil. The mower is ready to go in the spring after adding fresh gas.
JJThrasher
Indiana
With that maintenance schedule I'd be putting two or three engines a year in my mower. Its a near monthly experience for me.
jd_1138
NE Ohio
This. For the average homeowner mower, no goofy oil change reminder systems are needed.
AmishFury
yeah it really depends on usage... for average homeowner never changing the oil EVER gets them by surprisingly well
jn50308401
Wow.. a reminder on a mower? Hmm
At the end of the season I flush and scrape the deck, empty the gas and I change the oil every other year. I wonder if these companies are just making things hard..
Sent from my KFSOWI using Tapatalk
Marcm157
Newburgh, NY
I service my mower and snow blower at the end of their respective seasons. I drain or treat the fuel and I change the oil regardless of how much use they got each season.
FadedGray
W. Michigan
My newer Troy-built mower has a change oil reminder light that is set to every 50 hours. I do it at the regular service intervals and that should keep the mower happy.
humber2
Downunder
My 1966 Iron Horse 2-stroke gets fresh oil every fill.
I worked out the name of the Chinese lawnmower inventor, his name is Mul Ching.
G_P
Central CT
Some of these "service due" indicators can be reset by holding a small magnet on them.
T
TAB57
kirkville ny
Will look at the manual to see what to do (hope I can find it) and I do change the oil early before running or at the end of season. Just did the tractor and do that each spring as that is used all year long but is to wet to get on the lawn with that.
crbnfbr
SC
Hell, my 21" Troy Built self propelled doesn't even have a drain plug. It shows tip it on it's side or siphon it out.
Riding mower is on the wishlist.
Empty Pockets
Rural New York
I have quite a bit of property, Using a 29 HP New Holland and a mower deck, I still Change the oil every 3 months in the tractor and every season in the mower deck.
The tractor does double duty in the winter as a snow plow, with the front end loader. I bought more equipment than I needed, and it's done well by me for over 15 years
kctyphoon
Jersey/Staten Island
I change in the beginning of the season.. I use one of those hand pump vacuum canisters to do the lawn stuff. Got it from lowes a few years ago and it makes changing the oil a lot less messy.
