MP&C Shop Projects
MP&C
Leonardtown, MD
Robert I aquired a hammer from my dad when he passed, nothing extraordinary there, but I never remembered it and it is a different shape than I know of. So I don't have any history with it. Do you recognize this and what specific purpose does this serve? Can you help with your vast metal bashing knowledge/skills? TIA Harry
Harry, it looks like a blocking hammer, used in conjunction with a stump or sand bag to add stretch (shape) to a panel.
Monza Harry
Windsor ON
I had seriously considered it as that I just haven't seen that shape/mass-combo before I'm clueless as to a search term to investigate with. For your valued opinion Robert Thanx Again! Harry
MP&C
Leonardtown, MD
My body hammer rack has been running out of room, so I've been spending time lately cleaning up some of my extras and selling them through my IG account. One of the guys who just bought one of the hammers had seen my modified tight access hammer and asked if I could make one for him. Since I had a couple extra BF618's, I accepted the challenge. I had bought a hammer a few years ago from a retired body man, who must have needed a shorter handle at some point. Sad, because it was one of the older scripts. But we'll use this to make a new hammer that should last a lifetime.
The hammer head is dissected with a cutoff wheel, and a slight angle is sanded into our mating surface to provide more finger room given the shortened head.
The parts got TIG welded together using ER312 rod...
and cleaned up with a die grinder
Taped off, media blasted, and painted....
I had a replacement hickory handle that didn't have the faceted sides, so flats were sanded, handle fitted to the hammer head, finish sanded, stained and satin finished.
Assembled..
So the main reason for making this hammer is that Snap On does not make it with a crowned face. Their tight access hammer, the BF612 has a flat face, which is counter productive in most cases because you'll need it inside of a quarter panel or door, where typically you have a concave crown inside the panel to contend with. A flat face hammer is going to leave coin marks with every strike, the crowned hammer is more suited. The other issue to address is that with the short hammer head there is little finger room when the head face is parallel to the handle. With a slight angle added, we've increased the finger room..
Ready for shipment to MI.
Now my personal hammer (first picture) looks kind of sad, may have to clean it up as well.
MP&C
Leonardtown, MD
McMaster sells them for small ball peen hammers that don’t fit too bad, most all will need some work to fit the hammer head. I’ve gotten some from Beaver tooth as well. Genuine Snap-On replacement handles are stupid money, but worse yet is they **** for body hammers. This picture shows the comparison over the years. Looks more like they now use ball peen handles for uniformity in inventory. The one on the left hammer is about ideal, note how they USED TO make them thinner through the neck to isolate shock to your wrist. That hammer is also a good 60 years old.
Rockable
Oak Ridge, NC
Hammersource.com has lots of different handles. Most are not for metalworking hammers but they might have something.
Www.hammersource.com
Also, here is a source for Martin replacement handles that are very reasonable.
MP&C
Leonardtown, MD
Well in our typical back up and punt fashion, the original battery hold downs that we had already powder coated did not fit the battery, too short. So we ordered some round stock in stainless to fabricate some new ones.
A threaded standoff was modified to provide an angled surface for using as a hammer form to get the bottom "hooks" consistent...
All polished up...
Installed, and no polish job is complete without addressing the ends of the rods..
Assembling our vent windows, the excess rubber is trimmed using a No. 11 scalpel blade for a nice and tidy fit
All the bits assembled
installed...
And more stainless we missed, the parting bands for the front arm rests, complete with a form-fitted sanding/polishing fixture
MP&C
Leonardtown, MD
Thanks for all the comments guys. John, much of what I have amassed in knowledge and skill (besides the trial and error thing) has been learned from others passing on knowledge in a similar fashion. I am merely paying it forward as has been done with me. Thanks for the kind words, I can only hope my posts are helping others as I have been helped..
zmotorsports
Northern Utah
I did something similar on the ends of the axle shafts on my grandson's Radio Flyer project. When I masked off the parts for bead blasting and paint I masked the threads and shoulders but left the ends exposed for blasting, paint and clearcoat to add that little finishing touch. My son picked up on it right away the other night when he came over and commented on it.
I like how you squared off and polished the ends of the hold-down rods Robert. The devil is in the details and you my friend, are a genius when it comes to those devilish little details. :bowdown: :bowdown: :bowdown:
MP&C
Leonardtown, MD
Another BF618 hammer we modified. Using a 1" S2 tool steel round, it got bored with a 3/8 hole, and the chisel end of our 618 was trimmed and turned for a matching "peg" that gets pressed together with the bored ball. Then TIG welded in place using 312 rod and dressed out so it looks like it came this way. And yes, Snap-On should have made this one too. A low crown radius at the bottom and a smaller (1/2") radius at the top.
And here's a sample of the next set that will be finished this week, a set of Bonney with reverse curve faces.
MP&C
Leonardtown, MD
For something that’s destined to have a coat of filler I guess it doesn’t matter. In the realm of metal finishing, any nick or gouge is going to transfer to the workpiece. So a smooth hammer face helps in the interest of not causing any “side effect” damage.
MP&C
Leonardtown, MD
Snap-on, MAC, Martin Tools, etc, all make good hammers. For a more vintage hammer, Plomb, Porter-Ferguson, Herbrand, Bonney, Streamline, Proto, Fairmount (and others) are very good quality hammers that you can normally pick up much cheaper than a new Snap-on. Herbrand makes one with the ball end that was the inspiration for the one I made above from the BF618. I’ve started looking less at the name and more at function. I guess I started with Snap-On hammers because like many I was on the truck once a week. :ROFLMAO:
phred
NC
Thanks for the clarification on the polished faces. That was my assumption all along. Most of the vehicles I work on start out pretty rough so I’m usually in the stage of beating the panel back to a shape resembling how it started from factory. I then pass it on to someone that has more metal working skill than myself to bring the panels back to perfection. Hence my hammers are far from polished. 😂
Rockable
Oak Ridge, NC
Yes! Exactly! I saw Jesse using one on one of his videos and asked what it was. I bought one immediately. I'm guessing you may have turned him on to it. 😄
Hope you had a Happy Thanksgiving!
MP&C
Leonardtown, MD
Latest hammer modification, This one is a fender bumping hammer that I'm told works well on early vintage (20's-40's?) fenders. The barrel end seems to have not enough crown from end to end for such a fender without leaving coin marks on the ends of the strikes. So I thought I’d doctor up the extra hammer I have of these.
A round crowned face was turned out of some tool steel. And a bandsaw didn't want to touch it for the final cut, had to use a 4-1/2" cutoff wheel on this and the hammer.
With the barrel removed and the new face welded in place.....
Belt file makes short work of cleaning up the weld...
Still needs some media blasting and a paint job, but looks like this will do the trick.
NYBODYMAN
NY
NYBODYMAN
NY
Finishing touches added…
beautiful work.
Would you happen to know the model # of the Herbrand ball end body hammer or if not, would you happen to know any other manufacturers who made ball end body hammers (I'm referring to the small ball end one that you made above). Thank you.
MP&C
Leonardtown, MD
Sorry for the hiatus on the wagon, we've been waiting on some parts for windows and the tail gate, which have just arrived. So we'll be back on wagon progress in short order. Meanwhile, here are some more hammer cleanups. First is a vintage Blue Point "redhead" reverse curve hammer. It started with some nasty nicks in the hammer face and a handle that needed a fresh cleanup.
We start by removing all the nicks and abuse from the hammer faces, as well as removing any sharp edges followed by a polishing, to keep from transferring those defects to your panel. Then media blasted and painted. The handle gets thinned slightly through the neck to help keep the impact shock from traveling to your wrist.
Then the handle gets refinished. The fun part is removing the old stain (and stains) without removing the vintage logo...
finished and ready for shipment
MP&C
Leonardtown, MD
We also worked on a Heller 422, the bottom one in the next picture...
We had years of abuse to remove, nicks, surface rust, and casting flaws. When checked on a loose belt sander we found waves in the casting, so the belt sander was used to provide a more consistent radius. Then we followed our sequential sanding techniques, and finished out on the buffer...
Then the polished edges were masked, the remainder media blasted and painted
All complete, this one now resides in Delaware.
