Pluribus
Nice space! If you're willing to share, what did it cost for the floor heating system? I'm in the midst of designing a shop, and I'm intrigued by in-floor radiant.
Sure. I have a whole spreadsheet I kept for the entire build. But from my memory it was around 5k for the whole shebang. That's boiler and components, pex, insulation, and other bits. I did all the work myself though. Insulation, pex layout, manifold and boiler install, etc.
Thanks for sharing. Based on that, my guess is that I'm going to skip the in-floor. I'm in a temperate climate, and I'm willing to work at around 50 degrees, so I don't see it being worth it for me. My average January high temperature is in the mid-40's, with the low being in the mid-30's.
I can understand that rational. I keep my shop at 50, but our winters aren't nearly as nice! But don't forget, you don't have to totally finish the radiant system like I did...
Assuming you want to stay where you're at for awhile, remember you might change your mind someday. And it's always a good idea to insulate the slab even if you don't want the radiant heat. So assuming you WILL insulate, it won't cost you much more to just run the pex and finish the concrete. If you never use it, it's only the cost of the pex that you'd spend to have it there...the costly components are the heating system. Just my .02 cents.
Food for thought...thanks!
Then again, I do fear the snowball project. While I'm doing this, I might as well do this...and so on...lol.
