Rickochet
My 4 year old DIY Mr. Cool has worked perfectly through 104-degree heat and sub-zero cold without any issues. However, today I went out to my shop and noticed it was unusually warm and an F5 error code was evident on the inside unit. I went outside to see what the condenser unit was doing and heard the fan trying to run, but it made a growling noise and even attempted to run backwards. I checked the voltage to the unit, and it was 244 volts, so I figured it was something going on within the condenser unit. I checked online, and sure enough, the F5 error code indicated a condenser fan operation issue. I disassembled the enclosure a measured the resistance of the fan motor, and it was perfect. I noticed that there was some evidence of critter damage with chewing on the insulation surrounding the compressor. To facilitate further inspection, I removed the control board, and there it was! The fan wiring at the plug that connects to the PC board had been chewed in two. Only one power wire barely remained attached, and the other two wires were completely separated due to the critters' attempts to file down their teeth by using the copper wires. It's going to be a simple fix! Some solder and heat shrink will have the trusty Mr. Cool back in operation first thing in the morning!
The moral of the story is to spend some time diagnosing any issue before calling the high-dollar professionals out to service it. Why spend the big bucks when you can do it yourself?
