The manual for this unit is frustrating.
I know how to wire the power to the outdoor unit - no problem.
However, the cable between the indoor and outdoor unit is a puzzle. The manual says to match the colors based on the panel diagrams.
The indoor panel diagram does not include colors that match the provided signal cable. Ditto for the outdoor unit.
If I wire terminal 1 indoor to 1 outdoor, 2 to 2, and 3 to 3 (which generally matches colors between the units - ignoring the colors in the signal cable), then I am sending a hot leg to a terminal that the panel diagram on the indoor unit says is a neutral.
Indoor unit..
S = Signal (yellow)
N = Neutral (blue(black))
Lin = Line in or Live in (red)
Outdoor unit
S (black) = Signal
L1 (red), L2 (blue) = out of phase hot legs to make 240
So I know to connect the signal terminals together and Lin to L1.
The question is, is the indoor unit 120 or 240? That answer determines whether terminal 2 on the indoor unit goes to terminal 2 on the outdoor unit or if I have to provide a neutral at that terminal.
Indoor unit..
S = Signal (yellow)
Outdoor unit
S (black) = Signal
