k_ross
Hello everyone! This is my first time here, and am installing a 24K BTU Mr. Cool DIY A/C heat pump mini split system.
I finished the hard part already, which is the indoor unit, and drilling the 3.5" hole through my wall. I followed the directions and install video, and made sure the hole slopes downward towards the outside. I cut the supplied plastic sleeve and installed it in the wall, with some silicone caulk.
My install is on the second floor. I'm putting the outdoor unit on the first floor, on a concrete slab. I drilled a hole through the deck and ran the lineset through.
I'm currently waiting for the electrician to run a line to the compressor, which won't be done until next Monday. So I have some time to plan this a little bit.
Now my questions:
1. I was going to mount the compressor to the left of the back door, back in the corner. But it looks like the lineset is just a hair too short. Can/should I mount the compressor on concrete blocks to raise it up, so the lineset will reach? If not, I will just mount it to the right of the door, where the lineset comes down.
2. Should I wrap/insulate the lines with anything?
3. Should I extent the drain pipe from the indoor unit somewhere? Or should I just let it drip right there onto the deck?
4. I was going to fill the hole in the wall around the lineset with expanding foam. Is that a good idea? Or should I stuff some fiberglass insulation in there instead? Or something else?
Thanks for your help!
-- Kevin
Now my questions:
-- Kevin
