sgiss
1. Manual is pretty generic and not always accurate or complete - use common sense ( example it says remove mounting bracket from box, but doesn't mention that it is screwed into the indoor unit.
2. Look carefully at how the indoor unit mounts to the bracket BEFORE you do the install - you will not be able to see how the mounting clips while you are holding the whole thing up and trying to mount it!
3. The plastic wall sleeve is small.... install it after you have the pipe through the wall (make a larger cardboard sleeve as need to protect the lineset as you feed it through the wall)
4. The manual warns against kinking the lineset, but you can not really see the lineset with all the installation and wrapping. I might make the wall hole at a strong angle so that the bend in the lineset is not as sharp exiting the wall on the exterior.
5 Well packaged except the bottom of the indoor unit where the lineset is right against the bottom of the box... potential for forklift damage.
