I built a really nice backyard shed, heated/insulated/air-conditioned, a couple years ago...and installed a Mr.Cool mini-split for heat/AC. It's used as an office space.
A couple weeks ago, it started icing over when cooling. No extreme conditions (temps in the 80s/90s, no real humidity)--classic signs of low coolant. Called an HVAC service company to come check for leaks and service, for a $80 service call. They arrived, and suddenly, it's $500 for a basic service call because it was a DIY installation. (The install looks perfect and didn't leak at time of install; it's worked for 2 years. They just have a policy that any DIY systems are $500 for a minimum charge. I've called 2 other HVAC service companies with similar results.
$500 is half of what the system cost, and doesn't make a ton of sense...and that's before they even get into it and see what the problem is. I'm in the Folsom area, FWIW.
So...
How hard is it to find/diagnose a leak? I have zero HVAC experience before this (it was a pre-charged lineset install), and zero HVAC tools. Or keep looking for an HVAC company that's more reasonably priced? Or **** up the $500 charge because it's still half the price of replacing (and there's no reason to replace)? Or buy the tools and learn HVAC? Or other? No leaking oil, no obvious signs of leaks.
So...
