daseitz001
Hello all, I am new to the site. I just purchased a Mr. Heater Big Maxx 50,000 BTU, and have a vertical vent question. I am quite handy and can do almost anything, but have never ran a vertical vent. I know it has to be vented with B-pipe, and believe I can use 3" the entire run. I know to use and elbow coming off of the furnace to a straight pipe that goes through the ceiling pitched toward the roof peak. My question is what are all the pieces I need from the back of the furnace up? I want this correctly and know there are trim collars for the drywall, then bracing brackets. I have done some research and see I need to use a 6 or 8" pipe around the B pipe at the attic line to keep the insulation off the B pipe. I would appreciate a list of what I need to do the job. Thank you!
