Mr. Heater Big Maxx 80000 BTU Install
LIFTED
New York
After a year of insulation falling on me, I finally got all the OSB up on the walls and a metal corrugated ceiling hung.
I currently run an old furnace for heat off kerosene.
It works well, but takes up too much floor space in my 21’ x 39’ garage.
So I broke down and bought a Mr. Heater Big Maxx 80000 BTU from Northern Tool on Black Friday.
Last weekend I managed to manhandle the unit up and get it lagged to the trusses.
It is going to be vented horizontally- so I am planning to use 4” SS cat 3 single wall.
Got the 100# propane tank filled today, still a lot of work to do on the install in terms of venting and pipe routing.
Does anybody have a recommendation on a LP regulator?
TractorJeff
Elkhorn, WI
A 100lb lasts about a month on a 50k Big Max if used sparingly.
I keep it around 45/47 when I am not out there.
Regulators are available at Central Tractor.
I assume you have one nearby?
Home Depot and Lowes carry them also.
Natty Bumppo
Savoy, MA
I am doing the same thing right now. Just got my 80000 heater hung 2 days ago and am venting with 4" Cat. III stainless single wall. Going to work on that tomorrow. I have two 100 lb. tanks and am going with an automatic switch over regulator.
L
LIFTED
New York
Natty - where did you purchase your SS venting?
After what Showkey posted above, I may go with another 100# tank.
Do you have a link for the automatic regulator?
dfiler2
NW Minnesota
You still need a regulator, unless your switch has one built in. If you are in area's where it gets below zero for periods of time, I would use a two stage regulator, it will save you lots of frustration when it's really cold out.
Unless what you meant was having your switch then the regulator.
Natty Bumppo
Savoy, MA
I had a tough time finding it locally. All of the heating, cooling, and plumbing places nearby only stock the B vent, which no longer meets code for horizontal runs. Even Northern Tool offers a horizontal kit which by the looks of it is also B vent. I researched online suppliers and eventually ordered mine from Menards. Not cheap...but shipping was reasonable and it got here in 2 days. I got the Saf-T-Vent by Heat Fab. It's interlocking and has the built in gaskets.
The nice thing about 2 tanks and an auto-switch over regulator is that when one of them kicks you won't be left without heat until you get the tank refilled.
I am doing the install and black pipe and venting myself, but I do have a friend who is a licensed HVAC guy who is doing the final connect to my tanks and inspection before we fire it up. He found a regulator for me, so I don't really know what he's using.
Natty Bumppo
Savoy, MA
Thanks for the response. I will certainly be sure it's a two stage, as I do live in a very cold area. Did not know that.
I have a friend who is a licensed HVAC guy who found the regulator for me. I'll be sure to ask him what it is.
L
LIFTED
New York
Thanks, yes - I was looking at Supplyhose.com, the SS stuff is not cheap.
I plan to use 1/2" pipe for the propane - I only have about 6ft from the tank to the unit.
TractorJeff
Elkhorn, WI
FWIW: I used 3/4 Black going through the wall from the tank outside, then up and 2 feet left to get behind the heater. I figured the larger pipe would allow the propane to warm more before it gets to the Heater.
Showkey
"MEMBER EMERITUS"
Wausau WI
The vapor pressure is determined by the tank temperature and % full/empty, not the line or pipe temperature or size.
Low levels and low temperature the propane never leaves the tank.
L
LIFTED
New York
Got the old furnace out, the electrical done, and the exhaust buttoned up.
This is what I am thinking for the propane plumbing minus the fittings:
Heater > Union > Ball Valve > Yellow Flex Line > Drip leg (teed) > Black Pipe Thru wall > Rubber Flex Line ???? > Regulator > 100# Tank.
I have everything but the Rubber Flex line.
You are not supposed to use the Yellow Flex line outdoors - correct?
I need maybe a foot of rubber line from the hard line to the regulator.
Does anybody have a good source for this?
toyotadriver
I wouldn't use rubber line outdoors for a permanent install. Rubber will break down under UV rays. It'll last awhile but it'll fail before metal lines will.
L
LIFTED
New York
Plumbing and exhaust, ordered a rubber hose to finish it off,
TractorJeff
Elkhorn, WI
Update on Consumption: After 24 days of Holiday events (no shop time) I checked the 100lb Tank today and it was empty. It was still around 45 degrees so I am guessing it went empty sometime today.
L
LIFTED
New York
All done,
It's been heating for about 10 minutes now.
Seems to smell a little - I am thinking this is normal for the first fire up.
TractorJeff
Elkhorn, WI
Yes, in the Manual it states it will smell the first time!
Awesome being warm when you have been cold for a long time!
toyotadriver
The first time you fire it up new it'll smell a little as it burns off oils. It's ok. You might see a little smoke too.
Natty Bumppo
Savoy, MA
Looks great lifted. I finished mine last night too. Got it fired up and adjusted. I had some smoke and fumes in the barn for a few hours.
Luke_L
Elma
Interested in this. I've been toying with adding the 50,000 BTU version in my 2.5 car. How did you attach the vent pipe to the roof?
L
LIFTED
New York
Ha, I had something that worked perfectly in my scrap metal bin.
It was off an old soda carbonator - basically a SS formed angle with a SS strap.
