Well got the heater hung, gas run, and b-vent done. Heater fired up first time (great right?). After about 15 minutes it started blowing cold air. Turned thermostat OFF and the fan was still on blowing cold air. Unplugged the unit let it rest for 10 minutes, plugged back in. Fan immediately came on even though thermostat was still off.
The LED blinks 4 times indicating a high sensor limit or rolloff valve. The unit was cool (read not hot) so I tried to reset the rolloff valve, but low and behold not even listed in the schematic of all the parts.
So here I am very upset. Any ideas other than 'the circuit board is bad'? I ran 4 wires to the unit and the thermostat has 4 wires (the cheapest honeywell I could find). Before firing up the unit the fan auto/on turned the fan on with no problems.
Thanks.
Thanks.
Junkman in to cut off their kneecaps.
:... and modine was by far the best company I have ever delt with! I will give you my contact over there if you send me a PM. I don't want to beat this guy down with tech calls.
