MR Heater Big Maxx
Jwall82
At my residence
Im sure some of you guys have experience using the Mr. Heater Big Maxx. I purchased the 50,000 btu for my barn. I'm only up there once or twice a week. I was wondering if you don't want it to run constantly can you just unplug it or do you have to shut of the gas then re-fire it each time? Also I am reading I will need to install a drip line. Is this a simple tube hookup that I can run down the wall and drill a hole to the outside?
littleboss
You can plug it into a switched outlet and shut it off that way or turn the thermostat down to 40.
For the drip leg all you need is a tee on the gas line coming in. Put a 4" ****** with cap. This is the drip leg that collects moisture.
