Mr. Heater Forced Air Propane
TX63CONV
Dallas, TX
Any concerns with using a Mr. Heater 38k BTU (or other brand) Forced Air Propane Heater for my 20x20x10 attached garage?
I have a hand me down unit that I currently use and it gets the job done on the few evenings that I work in the garage. However, I have some automotive painting projects that are coming up and will need to keep the temps inside the garage above 65 over-night. The garage is insulated above, insulated on the demising wall to the house, brick un-insulated on the two side wall and then an uninsulated garage door. Lows on nights that I will paint will probably be in the mid to high 30s. Assuming I need to raise the temp 30 degrees from 45 to 65 (garage will be warmer than 45—but not sure all night). I should only need about 15,000 BTUs.
My biggest concern since it is attached to my house is safety.
Some other points:
I don’t have a moisture problem when I run my existing unit but I only run it for a couple of hours.
The garage door is not completely sealed—its sealed but there are a few gaps and should allow ventilation.
Door from house to garage is a sealed exterior solid wood door. This opens to a small laundry room with a small vented to the exterior fan and a door that opens to the rest of the house. In the past, I would paint with the garage door open but both doors in the house shut and the fan running. You cannot smell paint vapors in the house.
pv74
Boise, ID
Are you talking about a propane torpedo/shotgun heater?
I run a Mr Heater propane heater in my garage during the winter months.
I've never had an issue with it, but I leave a window and the garage door open a crack.
With painting, the only thing I would be concerned about are the fumes and an open flame.
I do know that my little Mr Heater will smoke me out of the garage within an hour or so on the coldest nights...it puts out a LOT of heat...too much heat may be a bigger issue.
T
TX63CONV
Dallas, TX
Yes, Mr. Heater "shotgun" fan.
What I have done in the past was to spray, open the double garage door, run the fan for long enough to vacate the cloud of over spray--I know there are lots of discussions/thoughts on this but I have been doing this for a while and I am not painting a whole car. For example, I am epoxy priming two axles hopefully next weekend.
Too much heat is probably a concern and I believe there are only two settings - high and low. I wish they made one a little smaller.
I am hesitant to go with the gas filled radiators as I worry that a few feet away from the radiator, the temp will be drastically lower.
Bretny
Dutchess county NY
Those propane tube heaters really burn up the oxygen in the air. They also dont havr much of a thermostat. If its a paint job you dont really care about i would do it. If you care about it wait until spring or get a vented heater.
