Thanks for all the help. The vent goes up last since I am going to have a professional come out and cut a hole in my roof. I just can’t bring myself to do it. I am sure I could but just too apprehensive it might leak sometime in the future. I will also have him look over the rest of the install to make sure everything is okay and won’t burn down or blow-up my house later since it is attached.
The little box in back where the power supply connects is not a service switch; it is just an electrical box to make the electrical connection. I just started running the wiring and went with 12/2 since I had about 50’ on hand. As I started to connect it, I noticed a tag inside the heater that states it only draws 3 amps max (see about the middle of the attached picture). Since I only know enough about electricity to be dangerous, why does this need to be on a dedicated circuit? I believe my coffee maker draws up to 8 amps. Also, why would it need a service switch if it could just be unplugged?
Again, thanks to everyone for the help. I do not doubt what everyone stated, I am just trying to learn and reason this myself.
