Joelk
I installed an MHU 75 in my Garage last fall. A Gas Co Tech installed the Propane lines and checked the flue and all other aspects of the installation. After I became aware of issues, he inspected again and verified that the gas pressures are correct.
When it was first installed, the unit fired up and seemed to heat properly, but this was in very warm 70-80 degree temps.
I only use the shop occasionally and during the fall I noticed that the heater would often start burning for a few seconds, then go out, then about 30 seconds later would start burning again for a few seconds, go out again, and then on the 3rd cycle it would usually start and continue burning normally for as long as it took to get the shop up to thermostat temp.
I did not think this seemed normal, but it always seemed to light eventually, so I did not worry to much about it.
Since it has gotten colder, it now sometimes fails to light. It seems that if it is 50 degrees or warmer in the shop it would start(after the sequence described above) pretty much every time.
When it is below 50 degrees in the shop, it frequently will not light(even after the sequence) and the control light will flash 2 times which is supposed to indicate a system lock out.
I took the end panel off of the unit and observed the burner operation.
When the ignitor starts clicking the bottom 4(of 5 burners) light almost in unison, the top burner often will not light, and after about 10 seconds the ignitor will stop clicking and the gas will turn off. About 30 seconds later another ignition cycle will start again and the bottom 4 burners will always ignite and the top burner may or may not light. IF the top burner does light it is ALWAYS after some delay. If it has not ingited after about 10 seconds the ignitor and gas will stop and after another 30 seconds or so another ignition cycle will start again. Again the bottom 4 burners start almost in unison and the top burner will sometimes ignite. If the top burner does not light the indicator light goes to two flashes and it will not longer attempt to light.
It often does start on the third ignition cycle and I suspect that this is because the previous ignition attempts have warmed up the temperature in the unit somewhat.
I removed the #4 and #5(#5 on top) burners to see if there are any defects in them. I found nothing abnormal about the #4 burner. The gap on the "flame channel" on the #5 burner looked very similar to the #4 burner, except there was a spot weld that was not holding and allowed a very slight gap at the back of the burner. I welded this gap shut and reinstalled. This did not seem to have any effect on the operation, and as before, the #5 burner ignition is always delayed, if it ignites at all.
Any suggestions on what I can do to get consitent ignition of the top(#5) burner?
Would opening, or reducing, the gap of the flame channel help?
