Mr Heater stopped working & propane smell
Dr Jay
A few weeks ago I installed my 50000 btu mr heater, checked for leaks and enjoyed lots of trouble free heat until today. Actually about three days ago i noticed the heat drop drastically after it had been running for several hours. I was running a newly filled 20lb tank as I don't have my 100lb filled yet. It was very cold out and it had been running for hours so I just shut everything down and thought the tank had ran out of vapor.
Today I went out and started the unit, felt for heat and went inside for a coffee as the garage warmed up. I ended up playing for a bit with my son and went back out about an hour later to find the garage was cold, heater was off and I could smell propane. I ran around the garage and turned off the tank and left the door open. What happened?
Tim The Tool Man
Lehigh Valley, PA
Tank valve froze? Tank empty? Did you include a drip leg on your install? If no, did debris get sucked into your regulator? 50,000 btu is a lot of btu's to run on a 20# tank. Are you using a 1/2" gas line? I would think you might not have enough line pressure/volume and the cold has exacerbated the situation.
Try a fresh tank but temporarily run it from inside your shop...
Camper
NE Pa
When my tank goes empty I get a propane smell in the garage.....I would start by putting a full tank on it
D
Dr Jay
I have 1/2" line with a drip leg. I agree the 20lb tank is small for the heater, I will try switching to the other full one until I get my two 100lb tanks filled.
Steevo
43.49600, -112.04300
Sometimes the small tanks aren't capable of the flow rate needed by something like a 50k btu heater. They can freeze up the valve or end up with liquid propane in the line.
D
Dr Jay
Thanks for the replies everyone, Nehog was right, to my surprise I had completely drained one of the tanks. Feeling a little stupid now, again thanks for the replies everyone.
