mr heater temp
Mike Honcho
Finally fired up my mhu50, and noticed the b vent is hot to the touch, about 200 degrees according to my surface probe. Is this normal? Burner tubes aren't glowing red. Thanks.
Chris
fury9
Mchenry, IlLaHnoYs
Mine gets hot, Can't touch it for long. Make sure you use the wall thimble if you went through the wall, keep combustibles off the pipe and you should be fine
