Much needed sticky! Difference between grounding electrodes &
Sticky! Difference between grounding electrodes & EGCs/grounds
We often get several posts a week here where someone is confused about the difference between a grounding electrode aka. a ground rod, UFER, etc. and an equipment grounding conductor/EGC aka. ground...
The following link should help clear up the confusion and I feel it would make a great sticky:
http://www.electriciantalk.com/articles/the-confusion-of-the-term-grounding/
W
Re: Sticky! Difference between grounding electrodes & EGCs/grounds
Bump!!
Any admins think this would be a good sticky?
Strouty
Southern Maine
Do you use those with PVC air lines? Or is this more about using the 16 gauge cord on my 300 amp welder. My cousin's brother in law has a roommate that knows how the code goes, he was a full time stock broker, but he dabbled in electrical too.
Redwolf947
South East WI
It would be great if someone (not me) were to go thru and link all the common questions found right here on GJ with the best answers
gc427
Glendale, AZ
:scared: You should use that 16ga cord to ground your PVC air lines! :thumbup:
W
Huh? :headscrat :eek: :wtf:
