Mud (foam) concrete jacking
pugsl
side
Have a 2 step stoop and decorative walk. the stoop and walk have sunk about 4 inches. Had mud jacking done in last home but have heard about foam DIY jacking. Has anyone done this and what did you use.
SolarColumbia
Wisconsin
Since no one has responded I'll put in my 2 cents. My understanding is that this is a contractor product requiring specialized equipment and cost based on sq footage. I know somebody whose brother had it done about a year ago and so far it's held.
P
pugsl
side
Hoping somebody had done it here. Keep reading about it but can not find anybody who has done it. Put concrete jacking with foam in search and lot of products come up, read and they all say for walls.
SolarColumbia
Wisconsin
I've seen info on using it for slabs, but not walls. It sounds expensive. My driveway has settled a couple of inches but I'm used to it, lol. There are YouTube videos on it.
chase237
Canyon County, Idaho
I've had it done. I'll try to describe my experience without getting too wordy.
Our garage had some drainage issues which cause the floor to drop. At some point the previous owner had it mud jacked which must have helped temporarily but they didn't solve the water issue. I fixed the drainage issue then worked on the floor using the poly foam injection.
One thing I noticed was although the holes are smaller, there are more of them. Watching the process it seems like the foam lifts are more pinpoint and the foam doesn't flow like mud jacking seems to. As a result we ended up with a few more cracks in the slab. Not a big deal appearance wise given where we started. My observations are purely an uneducated opinion based on what I was watching.
I also had a portion of the front porch done with no ill effects so I suspect the large slab of a garage floor is just more fragile given the large flat area vs a compact porch.
I'd do it again if I was in the need. I've since sold the house so I can't speak to long term results but I suspect since I fixed the water into the garage the problem was solved.
