Mueller Kueps bearing remover
atikovi
Suburban Washington DC
I bought this tool on Ebay a few years for no reason other than it was priced so cheap, even though I had no immediate use for it. Today it paid off in removing a differential bearing when a bearing splitter wouldn't fit without risk of breaking the discontinued speedometer drive gear. Pulled the bearing off in seconds, on the first try after less than a minute setup.
Stick-man
Mid-South Tennessee
Glad it paid for itself! It looks really heavy duty. However, correct me if im wrong, it is very limited to the size of bearings it will pull? I don't care for the chain but if it worked, thumbs up
A
atikovi
It's actually made to remove the inner race that is usually left in place after the bearing itself is pulled off. The bearing I removed with it is actually larger than what it's made for and had to find a longer bolt for the chain.
olsenmotorsports
Chicago, IL
That’s a great bit of kit. I don’t often use it, but when I do I am grateful for the low profile arms that grab under the bearing. Also love the chain holds it all together. it’s a joy to use knowing the tool will stay together and you don’t have to get the flack jacket out!
GeoBruin
And here I thought Mueller Kueps just made that beefy wrench extender.
