Multi oscillating tool suggestions
dogdad
Down south
Any thing good out there or do most go with Dremel ? Concidering Fein since I just learned about them. Looking to get a nice tool with multiple applications...
jd_1138
NE Ohio
All the major co's like DeWalt, Milwaukee, Ryobi, Porter Cable make them. Looking for cordless? If so, just buy the one that will accept your existing batteries assuming you have some cordless tools.
But corded is fine too, especially since it won't be used a ton (like if you were a professional). I bought an el cheapo $27 Ryobi corded one at HD that works well.
But be sure to buy quality attachments and blades. The cheap ones ****.
CTyankee
CT
Boss has a $300 Fein...I've got a $20 HF...Friend has a $120 Rockwell.
IMO, Rockwell is best bang for the buck.
jakemac
New England
The Dremel is only good for hobby work. I sold a ton of Rockwells to contractors that burned out their Dremels on the first or second job. During the 7yrs I was at that job, I never had a Rockwell come back.
Cruzan80
Denver, CO
Had a dremel version that I burned out, got a Bosch and haven't looked back. Wonderful version of engineering getting almost everything right. When I was reading reviews, everyone had it pegged as the best of the best, if you were willing to spend (better than Fein, which still retains some proprietary stuff from when they were the only one out there).
I also have the HF version for the dusty nasty jobs, so if I kill it due to grout dust or things like that, I don't mind.
Edit: Mine is the corded, not cordless others are referring to.
cgrutt
I have a Fein Supercut and it's AWESOME but the tool itself and replacement blades and other attachments are super expensive. I'm sure some of the other brands are just as good and more cost effective. If cost isn't an issue though get the Fein, it is really a well made and versatile tool.
DHCrocks
Hawaii
I have the Bosch 12v and it's surprisingly handy. Its' pretty smooth, vibration wise but I have nothing to compare it to but no complaints on that part. It does **** down the battery if you're using it continuously. I've used it to cut 1" trim when I din't feel like breaking out a regular saw. So it has decent cutting power. Get the carbide or at the very least the bi-metal blades. The regular blades don't last and will instantly break off the teeth if you hit a nail. one thing you should consider is the cost of the blades, they are unbelievably expensive, you can easily exceed the cost of the tool if you get yourself a nice collection of different types.
FigureItOut
Bentonville AR
Speaking of blades, I've found that spending more on the Bosch carbide blades yields a much better cut/cost ratio than any other blades I've used. Stay miles away from Dewalt blades, they're by far the worst I've tried.
Sent from my SAMSUNG-SGH-I337Z using Tapatalk
justme-
Boston suburbs
I agree you'll find good info in previous threads. I have had a fein variable speed multimaster over 15 years... retailed over $500 when I got it...would never consider anyone elses after the use I have had and comparing then in hand...others all feel too chintzy to me, and the one we have at work ( Rockwell) for odd jobs doesn't work nearly as smoothly as my fein.
jd_1138
NE Ohio
Festool makes one too, but I think Fein is considered the best with Bosch and Rockwell close behind.
Qualitytools
SOCAL
I have the Bosch and the Fein they are both great. I would stay away from the cheap ones as you get what you pay for :)
Furious Filipino
San Francisco East Bay
Having used various models on the job and at home, I would recommend a corded version by the big names. The cheap ones work fine, but you can feel the vibration and there is a difference when you start bearing down on a cut. For home use, I have the Milwaukee M12 unit, but the 1.5 Ah battery will last maybe 12" to 18" linear when trimming MDF molding, undercutting door jambs, and probably half that when I trimmed hardwood already installed.
southalabama
Brewton AL
I've got a dremel and a no name. Both work about the same. For limited use they are fine. If I were running one several hours a day I'd get a Fein or Festool.
danny.lockhart.7
Milwaukee is most durable. Had same saw zaw last 15 yrs. Works like new. And Rockwell cheap and good tools.. I bought a porter cable whole set did even last year... I doing roofing siding windows...
Sent from my SAMSUNG-SM-N900A using Tapatalk
texasranger
Maryland
I got the Bosch 3 amp kit with about 35 blades and sanding pads for $170 on amazon when I was renovating our living room. Feels solid and works well, although I never tried a cheaper one. So +1 vote for Bosch.
bcradio
New Mexico
This Bosch is the one to get here.
Also, I'd get an additional HF unit for the nasty stuff like drywall if you plan on doing that work.
D
dogdad
Down south
I've decided to go with Fein...but still confused on the old locking system vs the new locking system. I've read lots of the older post here and stuff on line....am I correct in my thinking that all the new starlock style accessories/blades will fit the older starlock system? Looking to buy a multimaster 350Q.....
UncleJoe
New Bern NC
I have the HF corded and when the cordless went on sale I grabbed it too. These vibrate a lot but I am not a pro working all day with mine. However my dad borrows mine a lot so between the two of us it has gotten a lot of use and we just can't kill it.
If you are not a pro and you only see yourself using it every so often why not buy a HF and save your money for a different tool that will get used more and you can step up to a better model of that tool. I think these tools are great for the jobs they do but how often do you really need it.
rice rocket
The whole OMT market has been threatening a refresh for about a year now. Have we actually seen the new tools come about?
thebeekeeper1
Illinois
I can't answer your question as I've had mine for several years, but you absolutely won't regret going with the best. Quality costs--but it's almost always a wise choice. You have chosen well! :beer:
