Hey everyone!
I am beginning to research installing a minisplit into my 1300sqft garage. It's attached to the house (in a manner that makes it less obvious) so it is shaped like an L. One side is basically a 2 stall garage, 24x25. The other side is almost a double deep two stall (and the deep side is where my lift will go). Fully insulated with R13 in the walls and R30 in the ceilings.
I was considering a 21k mini-split system with 2 zones (12k and 9k) https://iwae.com/shop/21k-btu-23-se...ystem-2-zone-wall-mounted-9k-12k-ha18624.html, but I see they get more expensive with multiple zones. Should I bother with two zones, or just get one big condenser and place it where I would likely spend most of my time? Thoughts?
Reason I like the two zone system is it will help distribute the cool air around the garage better than a single unit.
