If Fluk is still made in the USA I'd recomend Fluke. I don't believe Fluke is Made In USA any more so I recomend Extech multimeters.
Auto-range con-slower than manual range when you need to take a fast pulse measurement. I don't mean when you are in a hurry, I mean when the pulse only happens for a second. A momentary pulse from your truck popper for example. Many better auto-rangers have a muanal range button, this is fine.
Manual range-you have to know what voltage you are expecting.
Since you are looking at cheaper meters, you will likely end up with a non-true RMS meter. They give some iffy readings on AC voltage sometimes. AC voltage is found all over around the house, in 2 wire crank/cam/speed sensors, knock sensors, and in bad alternators, amongst other places.
And good luck finding a good one.Wonderful adjunct to a digital meter - but you must know how to use it.And good luck finding a good one.
I agree with the Simpson 260 fans! I have 2 of them, both with the white reset buttons on them, which was an extra cost, but well worth it. Have been using them for many years with no problems. BUT, I also have a Fluke muti meter, and Fluke clamp-on digital, for electronic and amp readings. By the way, does anyone still have the old amprobe clamp on meter? I do, and will pass it on only when I'm dead, probably to the wifes new boyfriend! Lol If your ony going to use it at home, I would buy yourself a cheap generic digital mutimeter, like a UEI.
Wayne
Agreed, they still have uses for the "professional". By pro, I mean someone who knows what they are doing. Kind of like a test light. It only belongs in the hands of a trained individual, not a homeowner that does not know when it is appropriate to use. Yet again, manual ranging meters could fall into the same category.
Seems most of the cheapest/simplest are not meant for the beginner.![]()
You mean this one?
