Multiple Ceiling Fan Speed Controller
abgiles
Yulee, FL
I had the recommended local electricians wire up my shop while I was away for work, including 3 Westinghouse Industrial 56" Ceiling fans (#7861400), with the GW5S-U (5 speed) controller. However, they failed to read the directions which stated that they the controller must control only one fan, and wired them all up to a single controller.
After about 20 hours of use, and fortunately while I was in the shop working right beside the controller, I smelled an acrid odor, and found the controller melting. I'm not a genius, but knowing that heat dissipation for an electrical circuit is based on I2R losses (current squared times resistance) and that if you triple the current, you're increasing the heat dissipation to 9 times original, and that's not good.
AF1QipNTi13Bz9Rq7G67mz30_hjQ5nCKG6z58b4TSNqw
AF1QipO_CdEFjJ7LTQzytnTjuEII2bQvB4_oWkn6GRXv
AF1QipPhua6p_rE5bzX0rf1ayfGZt2aemBQFPIaI8IaD
Unfortunately, I did not read the manual until after this happened, as I had assumed they knew what they were doing.
They have accepted responsibility for their error and vowed to replace the controller and set them up correctly, but I am liking the idea of a single switch to control all 3 fans.
Since there are only 2 wires from the controller, I am assuming it's a step down current transformer that's controlling speed, and all I need to do is find one with sufficient current rating to control the fans. (I cannot find the controller specs for the GW5S-U controller, but I did find that each fan draws .52 amps at high speed.
I'm looking at the 5A rated speed controller here: https://www.zoro.com/fantech-speed-control-115v-5-amp-wc-15/i/G4735367/
I'm thinking this would work fine, but wanted others ideas/opinions/corrections before proceeding.
Thanks!
Bert_
NW Iowa
Very common, the one you linked will work fine. No transformer inside it, most use a circuit similar to a dimmer.
wssix99
Chicago, IL
I don't think that fan control is going to work. The OP would need a multi-fan controller specifically for ceiling fans and rated for the total power of all the fans operating. I understand that fan controls for industrial fans are not the same.
A
abgiles
Yulee, FL
I have no knowledge of the industrial fans, and their workings. I can say that the speed control I linked to is for ceiling fans. The power ratings are there, so.... ?
If anyone has one they've used, please feel free to share.
Bert_
NW Iowa
I use ones like that all the time for multiple ceiling fans. The ones I usually get are made by Marley but they are basically the same thing. As long as it is rated for the combined load of the fans it will be fine. Most of them also have a minimum speed adjustment so the fans can be ran slow without stalling.
cory58
Charlotte, NC
Canarm and VES both sell multi-fan controllers for industrial ceiling fans. Can't guarantee they will work with your fans, but I've gotten technical questions answered by contacting both companies directly.
Cory
Sent from my iPad using The Garage Journal mobile app
