In my research for a/c options, my budget and use has pointed toward window a/c units. I have a 30x50 building with 12' wall heights and 16' at the peak. I have it insulated with 3/4" foam board insulation with radiant barrier on the roof and walls. My plan is to install two 24000 btu window units. My thought is that during the milder parts of the year I can run 1 unit and in the the heat of the summer run both, thinking this would be best for controlling humidity. I am located in North Florida, and primarily use the shop in the evenings after work and the weekends. Any input would be greatly appreciated.
