raymon1717
- Joined
- Sep 15, 2006
- Messages
- 17
Did the cleaning last weekend and ready to etch this weekend. I received the Epoxy-Coat kit finally and the bottle of acid/degreaser that came with it is really small. Most threads here recommend to use it straight with no dilution. For this reason I went out and bought more straight muriatic acid. How should I dilute this stuff? I plan to use the Epoxy-Coat supplied solution to clean, rinse it, then the apply other acid I bought for another etching application.
By the way, the kit that got delivered from Epoxy-Coat was f'd up. No squegee, and component A spilled into the large bail it came in. What a mess (all the tools and flakes were covered in it). Called them and they are supposed to be sedning me a new tool kit with everything but the epoxy (apparently the spillage of Part A is no big deal since it doesn't harden until it touches B anyway).
Also, if you measure out in units, how do you know how much of each component to mix at a time?
