Must Have DIY Tools
JA5544
Tn
What are some tools have you guys/gals found to be extremely handy around the house? I’m not looking for screwdrivers, cordless drills, hammer, etc. I’m more looking for things that may not be obvious to everyone. I’m hoping you all can lead me to an awesome new tool.
My addition to the list is a right angle drill attachment.
I have run across situations in the past where I needed one, but I usually just found another way to get the job done. I picked one up a couple months ago and have used it several times since. Every time is use it I ask myself why I haven’t had one all along.
jd_1138
NE Ohio
The Basin Buddy by Superior Tool (USA made) is awesome for installing faucets and supply lines. It's only like $10. I think it's rebranded by some other brands as well. You can put a large extension on your ratchet and use the Basin Buddy to easily undo faucets and supply lines.
Also, a hook and pick set is very useful for many tasks. Most average homeowners don't own a set, but they will improvise and try to use the end of a coat hanger or something.
Shane6377
That depends how you define "DIY". I have the tools of your average contractor, mechanic, plumber and electrician.
I can't remember the last time I hired anyone to do anything for me.
CJM8515
A nut and bolt assortment, well even more so an assortment of nuts,b olts, fittings, etc, etc.
1/4" SAE and Metric 6 point socket set with "hand spinner"
Look for one with a 1/4" female drive in the top. Add a 1/4 breaker bar for that little extra.
J
JA5544
Tn
This is exactly what I’m talking about! I don’t how many times I’ve layed under a sink and fought with a pair of channellocks or some other slip joint. Never really thought to find the right tool for the job.
Shelbylex
Manual impact driver. You will almost never need it. But when you do, you will understand why it’s great!
IndyGarage
Indy
fluke multimeter.
Cordless shop vac
Digital distance measurer
Klein zip tie tool
digital inspection camera
Tube wringer
sewing machine
microscope - for fixing cell phones and surface mount electronics
tire changer and balancer
JerryC
Memphis TN
A tool belt. Having what you need on the belt is way better than trying to find a place to put the ones you are not using at that moment. If you plan on working on a ladder a tool belt is huge plus. Mine typically has screwdrivers, claw hammer, tape measure, box cutter knife, small level, electrical tape and pliers on or in it. There is still room for other things that are job dependent like wire strippers, wire nuts, screws/nails, etc..
xjfish
I use a soldering iron/gun a lot for electrical repair. Pick one up an old goodie at a garage sale for $2...
Indexmill
Central NC
Really, you are on GJ and asking this question? Have you read any posts and looked at any pictures on here? A simpler and better question is: What tools does one NOT need?
MushCreek
Upstate South Carolina
I have enough tools to build, wire, and plumb a house. I also have a full machine shop and welding. The only tool I bought that surprised me with its usefulness is an oscillating multi-tool. I use it more than I thought I would, mostly for making 'impossible' cuts, and detail sanding.
P7M8
Maryland
A set of digital calipers. Knowing precise measurements of bolts, shafts, O-rings, etc. can save a lot of time and aggravation.
engineer2
Chicago burbs
Household tools:
Magnetic stud finder
Torpedo level
Headband flashlight
Miter saw
12 gauge extension cord
Battery powered impact driver (my most used tool)
Multimeter
Wonder Bar
Mr. Wonderful
Household tools:
Torpedo level
Headband flashlight
Miter saw
Multimeter
Wonder Bar
+1 on the multimeter. I started with the free one from HF and wound up using it to fix my dryer, oven, furnace and dishwasher! All were simple parts but I needed the multimeter to identify the problem. I didn't have a lot of experience using one but the youtube videos of the repair work always walk though it.
Robinson1
Kentucky
Im a contractor so I cant really answer this. Most homeowners I work for have a random screwdriver and hammer in a junk drawer. So playing off this logic any additional basic handtool would be an improvement.
If you're talking basic home maintenance/handyman type repairs. An 11 in 1 screwdriver and a pair of 420 channellocks will fix alot. I'd assume everyone reading this already has those tools. How about a Stanley 220 block plane and good assortment of drill and screwdriver bits.
If you're talking serious DIY I'd say the most important thing you can have is a basic assortment of common use fasteners and parts. At my house I cant tell you the number of times I've got a random plumbing or electrical fitting off my service truck to fix something in the middle of the night. Or the amount of calls I get from my customers for a 15 minute quick fix job. I stop almost every night and do some random small job on my way home.
J
JA5544
Tn
Maybe I should have went with a different title. I’m looking for tools that you find extremely handy that not everyone on this forum has. Something that maybe somebody hasn’t thought of. I think it’s safe to assume the majority of the people on this forum have the basic tools covered.
Davefr
OR
A professional auto tech only needs a shoe box with a few metric tools but a DIY'er has it much, much harder.
Let's see what a DIY'er needs:
- Automotive tools
- Carpentry/woodworking tools
- Plumbing tools
- Electrical related tools
- Appliance repair tools
- HVAC tools
- Machinist tools
- Computer repair tools
- OPE repair + lawn and garden related tools
- And tons of storage for all of the above
Bessy
Ontario, Canada
Definitely second the manual impact driver, that sucker has got me out of a number of jambs in the past. A good plastic faced deadblow hammer, digital laser thermometer, Franklin stud sensor, scratch awl, ice pick (basically a long awl with a wooden handle) flexible hose clamp nut driver, angle finder, and a contour gauge. Those are the oddball tools that don't necessarily get used every day, but are worth their weight in gold when you need them.
I find them to be oddly satisfying when I know I have them and can get to them when I need them, and equally disappointing when I know I have them but not in reach, so always consider where you will use the seldom use tools, and put them exactly where you'd first think to look for them.
Sent from my Pixel 3a using Tapatalk
MrDeerHunter
Oscillating saw has been useful as pocket to me. It is good for cutting bolts to cutting out sheetrock. I love it.
A six foot level has been quite handy too.
Irwin quickgrips for holding any random object.
Also the cheap 4 prong spring grabbers.
Sent from my moto z4 using The Garage Journal mobile app
