signcrafter
- Joined
- May 9, 2012
- Messages
- 12,634
The front center jacking point is hard to reach without a low profile jack, and even then its not possible on some models without a long reach low profile. So ramps help or driving the car on some 2x10 pieces to make jacking it up easier.
I just picked up a low profile jack from HF. I have a few other jacks but have been meaning to get a low profile for a while now after working on some VWs.
wheel hangers.
http://www.amazon.com/dp/B00WV5SF3G/?tag=atomicindus08-20
Not exactly a "must have" but a difference maker for sure.
I've been meaning to pick some of these up also. Any reason I can't just cut the head off some bolts and use them?
E-Torx
Torx
Metric Allen
3/8 drive ratchet guts in ¼ frame. Snap-On sells this and others may also. It allows you to access things in the engine compartment that you couldn’t using a 3/8 -> ¼ adapter. If you buy nothing else from the tool trucks get one of these. It allows you to use your 3/8 bit sockets in tight places and there are a lot of tight places.
Torque wrench- 3/8 & ¼ Please get good ones. BMW’s do not do well with over torqued bolts. Nm scale is a plus but converting from Nm to Ft lbs is just a mouse click away.
BMW scan tool software and an old ThinkPad. These cars have lots of manufacture codes that go well beyond OBDII.
Hope this helps.
Cheers,
Chris
I have the standard torx, etorx, and allen sockets. Any particular "special" ones I should get besides the low profile hex for brake calipers?
I believe I have a 3/8" in a 1/4" body but will have to check.
Torque wrenches I'm good on.
I don't have a BMW scan tool but do have an autel 708 which from the little I've played around with it on the BMW it can do a lot of things. Can register the battery which is what I need it to do now. Then after the alt and battery is fixed I will see what codes I'm left with.
Another project that is on the list of things to do. Think I even started a thread on wood ramps last year when I was working on a jetta. I'll have to see how the HF low profile jack works and build some of these if needed.
