Rolling_Thunder
Hello All, About a month ago I posted that I finally had a project to do in my workshop! So here's where Im at with it!!
This is what I started with: 1973 Mustang Mach 1, 429 BBF, Built C6 ******, 9" rear w/3.90 Posi
I have replaced the entire front suspension including the Power Steering Box on the car. I also cleaned up, coated with a rust converter and undercoated both front wheel well areas. New front calipers and pads.
Cleaned up:
Rust proofed and undercoated:
Suspension completed on the Front End:
All the new Stuff I had to install!!
Removed the rear suspension, cleaned the rearend up and painted it. Replaced the axle bearings and seals, cleaned up the Wilwood calipers and rotors and installed new pads. Also disassembled the Wilwood parking brake calipers and got them to actually work.
Before:
After:
I was going to clean the rear section of the car and undercoat it. I was going to do the rest of the bottom of the car later on, then my son came over for father’s day and he talked me into removing the exhaust and doing the entire floor now while the rear was out and I could easily remove the exhaust. So the exhaust is off cleaned up and painted an aluminum color. The underneath is just about ready to use the conveter on and undercoat.
The car came with an Art Carr Winters shifter in it, I really didn’t care for the shifter and it needed a new $85 plastic casing for it to be mounted. So I decided to buy a new shifter, after some internet research I ended up buying a B&M Pro Ratchet Shifter, it seems like the right choice for both Street and Strip use. It definitely looks better in the car and works much better than the Winters did!
After the suspension is completed I'll be putting on the new fiberglass front bumper, also bought a new 3 Core aluminum radiator and need to replace the front main seal it has a small leak in it! After that it'll be heading to the body shop for repairs and painting.
“TOMMYK” from this forum told me about the 7173 mustangs.com forum and it’s a lot a lot like this forum lots of good people and a wealth of good info! BUTTTTT I do have one complaint about the forum. There are so many cools pic’s and idea’s from it that its costing me extra money I didn’t want to spend!! Like I was going to polish and put new tires on the wheels that came with the car but there was a thread where everyone was posting pic’s of their wheels and I saw a set I just had to have!!! So $1200 later I have a beautiful set of wheels and new tires to make my Mach 1 look even better!!
More to come!!!
Cleaned up:
Before:
After:
More to come!!!
) of the shock towers and install grease fittings in the upper control arm ends. The upper arms were a common source of suspension noise.
