I'm sorry to be a pain, but why are those brackets always welded so they form a pocket? Isn't anyone worried about them collecting mud and rotting out? Thanks for documenting this build so well, I'm learning a ton.
Ditch the spikes! Just ruin the otherwise clean look IMO.
Nice looking welds though.![]()
keeps the rear end centered from left to right. if he used a pan hard bar it would move up and down in an arch ( if you were watching from the rear )
Bigpokie is my official answer guy!!!![]()
So yes it keeps the geometry better lol.
I've never done a Watts link. Always wanted too though. Just never needed too
I went back and looked at the pic. Wow that color is a touch to dark for me but that beer bottle brown/ root beer brown is such a cool color.
I dig the copper lines too. If you put a clue of fake rivets near the inlet it would be totally steampunk
Ok so I have not really liked all the plastic air tubes since the beginning of this project. They are prone to fail, and I simply don't want to trust my ride to them. Weakest link you know...
I want hard lines for the whole system at some point. So tonight I took off the tank to tank line and ran some copper line in it's place. The next line I'm going to run is from the filters to the tanks, and then from the tanks to the valve. It has been a while since I have soldered any joints. Not since the last water heater went kapoot!
Eventually I will do the main supply line from the York to the filters, but that hydraulic line is doing a fine job at this point. And naturally I will do all 4 corners to the bags. One less thing to worry about! My stuff may not be as pretty as some of the show trucks I see, but I want mine to be mechanically sound first.
Looks a little steam punk to me!![]()
........They are prone to fail, and I simply don't want to trust my ride to them. Weakest link you know....Looks a little steam punk to me!![]()
Those air lines run millions of miles on commercial vehicles every single day. I'd honestly trust them more then a hard line, any flex in the hard line can crack it. The only place that's not plastic on commercial vehicles is from the frame to the axles, rubber flexes better with the movement of the axle.
Rigid copper pipe is a bad idea on a vehicle.
if you don't want plastic use copper tubing.
