What R value will I be?
There is no "barrier." The foam is sprayed directly onto the metal.
Yep, that's pretty awesome!
Don't you have to cover the spray foam with something? Sheetrock, osb?
Sent from my Nexus 6P using Tapatalk
My understanding is the barrier is between the "living space" and the foam... What did you end up doing? Open or Closed and how did you see it priced?
Thanks in advance!
Is your garage cool?
Great place. Do you plan on finishing the floor? Just curious. I have about 1200 SF that I want to have ground and sealed.
Interesting project. I like the sprayed foam. I have it in my shop ceiling. You should consider finishing the inside walls up to eight feet. The foam is tough stuff but it won't hold up or maintain it's good look if it takes a beating.
