My "Adirondack Conversion" Project
J
Jawgarage
Near Cape May, NJ, USA
Thanks. When it is all done the extra touches like the large cupola and the cedar brackets (there are 8 more smaller ones still to mount) and special order green trim, soffits, and gutters will have added about $3,500 to the total cost. More than I wanted to spend but I agree it looks real nice and as another forum member said in a different post ...."...do it once and only cry once....instead of doing something over later at an even higher expense."
As for the driveway, two things: first is that in front of the new section with double doors the driveway is only about 14' wide which means I need to widen it so a car can turn and pull/back in. The plan here is to maintain as much of the grassy front lawn area look by using those commercial grade "egg crate" sort of pads that you embed in the sandy soil and grass grows through them. These are iften used in auxiliary parking lots and very very often along the NC shore in the Outerbanks for driveways on homes where there is strict code on permanent lot coverage. These dont count as grass grows through them.
Second, as to the need to build up a slope to the slab, its only about 7" at the highest. This will be done once the spring comes and I get the asphalt guy in. As you can imagine I have a few edge patches to make too along the 700' long driveway not really designed for all the wideload and heavy equipment we've had rolling up and down.
EOC_Jason
Bentonville, AR
Are there any special grounding issues with having that tower so close to your building? Are they going to be tied together?
J
Jawgarage
Wow.....interesting question that nobody has raised including building inspector. Electrical inspection being done this week though. There is no tie into the garage though. Would it make sense to drive a copper rod into ground and run a bomding wire to the tower anyway?
J
Jawgarage
With a couple of more warm days we got some more work done on the exterior.
Here's the latest:
Wrapped the facia and rake boards and window trim
Installed the Soffits
Installed the two upper Gable brackets
Installed the brackets on both sides of each dormer window
Dug trench for electric and did all rough in
Had electrical inspection and given go ahead to energize
Installed basic outlets/lights/etc. and will have final electrical inspection in two. weeks.
Had final Framing inspection with NO issues
All in all it's going great!!!!
And yes.....the crew missed a measurement and wound up 10' short of soffit material for the front .....special order too so it will be a couple of weeks before that can get finished and gutters put on.
EOC_Jason
Bentonville, AR
Oh I have no idea, that's why I was asking, lol... I'm assuming the tower has a couple ground rods of its own?
I was curious if lightning would arc across from the tower to the garage and in that instance which would be better, a bonding wire or not.
