thieltech
thanks. here's a shot of the loft, as it sits right now. i'm going to clutter it up with a good bit of equipment from the garage below while i sheetrock and finish the garage, and then i can go back and organize it. i'll probably start a garage build thread in the coming months, as i feel i'm finally far enough along to justify it.
that access door is just a temporary one, but i needed something i could open and close, and walk on while im up there working. it is just a basic 2x4 frame with 1/2" OSB. it is far too heavy for my liking. i will eventually be building a new, lighter version once the rest of the garage below is finished. I have a thread for the trolley and hoist here, but the winch is just the HF 1200 pound unit that many others have used.
even though the 2 stage is only drawing air in 1 cylinder, the CFM is rated much higher than my quincy. is the volume of the 1st cylinder of the IR pump greater than the two cylinders on the quincy 210? if so, wouldn't the IR pump always supply higher CFM than the quincy, even at low pressure? and if that's the case, would it just make sense to use the 2 stage exclusively?
WOW that is upstairs of your main shop !?!? thats pretty awesome ! i wanna do the same in my shop upsatirs . i have tons of cabinets like u have up there.
Can you post more pics of the whole shop and outside pics of the garage plz?
