My disc sander experiment
bugzilla46310
Demotte, IN
Since I can get abrasive blades for about 1/2 price of sanding discs, and when I cut metal on my table saw I use the blade to debur the cut, thought I would try one on my trusted Simplex sander. Had to drill and tap the shaft and fabricated a thick spacer washer then a heavy washer to clamp that to hold the blade. Tried it on a 2x4 and it worked good. Left a finish of about 40-60 grit. Now to see how long it lasts.
alwaysFlOoReD
Airdrie, Alberta, Canada
What is your machines operating rpm? I would fabricate a guard...
Crowbarman55
I use 20" disk at work to cut case harden steel linear rails from 5 mm all the up to 65 mm. We sometimes apply side force to the blades and when they explode, it's very dangerous even with the thick steel guards we have. Will make you poo your pants.
Todd
PCustoms
VT
The cutting disc is against the 14” steel disc that the paper disc would be glued to so there will be no side loading. Guess no one ever saw a disc sander with out the paper disc on.
Still not a good idea, but it doesn't matter what any of us think.
whateg01
doo dah, kansas, usa
Well you didn't say that, did you? It reads as though you replaced the whole sanding stuff end with a cutoff wheel. I would still be more concerned about an abrasive cutoff wheel breaking more than a sanding disc.
NORTON'S SHOP
Upper Midwest
Are you the same guy that made a Youtube video using old CD's as a cut off wheel?
tarbellb
Oregon
The backing plate makes it a LITTLE less sketch
But my question is how is a abrasive disc cheaper then a proper fiber disc?
If you post your requirements these tool hounds will sniff out a bunch of deals on the proper abrasive.
Until then, keep out of the way and be ready to change your britches
PCustoms
VT
They're like $10 at Grainger, So I have to assume there's plenty of options in the $5-$15 range
