My dream 60x96x16
cj7jeep81
S.E. Indiana
Thanks for the info. That route would be a lot cheaper to finish off the inside vs framing interior walls. Last couple questions (sorry). What spacing did you use on the inside horizontal pieces? Looks like more than 24" spacing. Any pics on how you attached your outlet boxes? Did you just nail them on top of the horizontal member?
Cjk
Wisconsin
Very nice shop. I had a 50x72x16' started earlier this winter. The site was leveled and the poles are in the ground waiting on the builder to return.
I see you have all your electric and plumbing inside the wall. It does look nice and clean. How did you lay the outlets out so as not to end up on a rib? I am planning on just running conduit on the inside walls but may have to reconsider.
Sims5
Mount Vernon, OH
The interior nailers are around 29" with the one closest to the floor being at 48" from the floor. The electric outlets are in metal boxes with tabs and screwed on the top of the 2x6. They were loose and moved between the ribs as the steel was put up. The 3 switches and outlet by my man door have conduit between each box with the appropriate spacing. This was done so when one box was moved they were all moved equally. My electric isn't in conduit, saved some $. I was going to mount the boxes on the surface and my electrician said " no way! ". Sorry I didn't take any pics of this.
Good questions.
Good luck with your building.
MSD Shop
Bend , OR.
Chad, did you attach the bat insulation to the 2x6's or is it just hanging there under the 2x4 stringers?
Can't wait to see your move-in pics :beer:
Sims5
Mount Vernon, OH
According to what I used in two weeks, I'll use about 350 gal of propane. The same 350 gal also heats our 2000 sq ft house when it's below 35*. Above 35* we use a heat pump.
The insulation is "hanging" in the walls. On that not, the insulation company was back today looking at why I ha the frost and condensation issues. We found that the baffles weren't instauled correctly and they will be back to fix that and re blow some in the attic. Took some steel down and found some gaps around my air lines. These issues will be fixed.
J-man67
Delaware
Damn. I wish I used 350 gallons of heating fuel/oil for the season! I have been thinking about a hybrid system...
Sent from my SAMSUNG-SGH-I747 using Tapatalk
Sims5
Mount Vernon, OH
Sorry, after reading your post I retread mine and realized I didn't type as fast as my brain was thinking.
I will use approximately 350 gal a month of propane to heat the house and shop.
J-man67
Delaware
Ahh OK, now I feel bad for you haha. I'm going through 250gal of heating oil per month for a 2200sq ft. Seems like too much to me. It's dual zone baseboard. Great heat but pricey. We also have 2 a/c units. One in the attic, the other in the basement so the duct work is there. I have been wondering lately if I can fit the air handlers with heat cores or whatever is involved with an electric heat pump. Maybe wishful thinking. Sorry to ramble on but your post got me thinking... Carry on
Sims5
Mount Vernon, OH
Got my air compressor yesterday. Should get it all plumbed in tomorrow.
10hp 80 gal Polar Air by Eaton Compressor.
MSD Shop
Bend , OR.
OMG so jealous, I have been looking at quincy's , how does this compare? got a link of where you bought it?
BHR4CE1
Long Beach, CA
Reading all these posts talking about temps in the single digits really freaks me out. We dropped into the high 40's overnight last week and I was freezing!
luke7734
Crestline, Ohio
Beautiful isn't ? :lol_hitti
I'm watching my wood stack dwindle quickly the last two weeks.
I cut a cord of oak and cherry last Saturday. . It'll be gone by the end of this week.. :spit: good thing I got 280lbs of coal to help get through these nights.. ;)
holy huge compressor.. is that thing 2 stage?
Ppwcanada
Nipawin, SK Canada
Hi Sims, Thank you for posting your build! I am doing a 70 x 80 right now, the pad is done and waiting for the builder to start erecting in mid Feb. Was going to go painted board inside until I saw how nice the tin looked!! You have changed my mind in a few areas, so thank you! I am sure I will have a few questions for you shortly!
Sims5
Mount Vernon, OH
Your welcome. I've stole every good idea I've seen and tried to have it in my build. Hopefully my posts will help others.
Ask any questions at anytime.
Good luck with your build!
tomsmith
Sims,
Congratulations on your build! It looks awesome and well designed. I love the in floor heating
Sims5
Mount Vernon, OH
NUTTSGT It actually is plumbed solid but it is mounted on 1/2" thick rubber feet under the boards. I didn't have a 1" hose made so we decided to go ahead and mount it solid. It actually doesn't vibrate so I might not add the hose. If I decide to add the hose it will be easy to add.
tomsmith. Thank you for kind words.
Hardware
Bucks County PA
Great Build.. you will love the epoxy floor... especially when you wipe up an oil spill with a little simple green and it looks brand new again!
rinker1
Great Build!! It's been fun watching this one come together. Soon as this weather straightens up a little, a gas line is going in my garage. I've got a Dayton G73 electric heater buts it's not cutting it for me. Can't wait for tonight -14 degrees !!! By the way, your pics are working for me.
Sims5
Mount Vernon, OH
rinker1. My gas line is currently on top of the ground. With Ohio, who knows when better weather will be here!
Thanks for the compliments
NUTTSGT
Northern Central Ohio
If you decide to use a hose, check out the hydraulic hoses at TSC or Rural King. If they're not larger enough and nobody local can make one, Industrial Hose up here (Bucyrus) might be able to.
Sims5
Mount Vernon, OH
NUTTSGT Thanks for the heads up on the hose. It will be a 1" hose, if I go that route. I don't think I'm going to need it.
