Ok! My Epoxy-Coat adventure begins!!! I am the lucky winner of the Epoxy-Coat contest! A full kit is already in its way!!!
This will be my 4th floor to cover with Epoxy… first experience with 100% solid epoxy. So prep is everything and I find my slab to be very smooth and I have 3 cracks that have been filled up with epoxy and must be grinded down even with the floor. So I’m looking into diamond grinding, hopefully my local tool rental shop has a diamond grinder available!
My garage is a single car garage, 12x19 rectangular shape with a drain in the middle. So I’m thinking 2 coats and flakes. My question is, can I divide my garage into 2 sections at the drain having 2 areas of 12’ wide (full width of garage) by 9.5’ deep, making it easy to start from the back of the garage and work my way out…but how would I batch mix? I would need a quarter of the full kit for every batch? How much sq. ft. does one batch cover? I’m guessing I’ll need extra buckets if I’m doing 4 batches…?
Any comments/suggestions are welcomed.
I will post pictures when I start.
Thanks!
mat
Thanks!
mat
