New to the board, and just got done installing Epoxy-Coat system on my garage. A little background to my project. I bought a new construction home about 2 months ago, that had an "epoxy coating" in the garage the builder installed. The day after closing date, my wife pulled her car out of the garage and the beautiful coating ripped right up. The peeling continued and continued, until we decided to strip up the entire coating (thank God for builder warranties). After questioning the builder, he said that he had gotten bored one day, so he decided to coat the garage floor, digging a little deeper I found he did not prep the floor because he thought you only had to prep dirty garage floors. So basically the most important step was left off, the etching and preparation for concrete. Well after stripping up the residual coating, I purchased an acid solution at Home Depot, which after applying I was still not satisfied with the prep of the floor. I then decided to rent a 7 inch diamond grinder with vacuum (BTW makes very little mess). After this step I pressure washed off residual dust and let the floor dry. I checked the pH of the garage floor and was satisfied. I also taped a plastic bag to the floor, left over night to check the water content of the concrete. After all of this I had to decide which flooring to install. I ended up going with Epoxy-Coat because of ease of application and cost. It was delivered very quickly (2 day delivery). After getting the product I arranged all necessary supplies and laid down a lot of plastic (this stuff is messy). My garage floor is 360 sq ft. So I needed one full kit. Each full kit will allow for 4 batches to be made which cover essentially 120sqft each with ~9mil. I divided my garage into 4 equal sections 9 x 10 ft. Mixed a single batch of Epoxy-coat, and applied to the floor using brush for edges and sides, squeegee for spreading and 9 inch 3/8 nap roller for even coating. After backrolling this section I started mixing 2nd batch. Applied the same way. Backrolled both sections and applied Alum oxide and flakes to first section. This continued for next sections. I ended up using all of part A and B, cleanup was quick (again stress plastic covering) Now I will just wait until full cure (3 days) before walking on or driving on floor. I will give updates as they are available. Feel free to email [email protected], or PM if you have any questions. Attached are pics of prep, midway, finished. I also have 50 or so pics of process on a snapfish album if anyone is interested.
