my epoxycoat floor one year later
mrobins297aaa
south east michigan
Just thought I'd write a little review after having my 2300 sq./ft epoxycoat floor down for one year.
I have not abused the floor or have i babied it.
Actually i just mop it for the first time this week. (only because the wife said "you should be a ashamed of yourself....look at this place")
It has not lifted anywhere that I can see and after mopping it it still has a nice shine (I did only one coat and did not apply the clear)
It has been thru many oil changes and a few brake jobs and two transmission changes all of which I have managed to spill any available fluid that goes along with those jobs and it has cleaned up well.
it does seem to mar easy, like if you drag a sheet of plywood, lifting one end and letting the other end drag on the floor.....it will leave a mark. so will sliding a wooden "A" ladder on the floor will do the same.
The one thing I would do would be to use smaller application squares than they reccommend. If I remember right the instructions said 128 sq ft per mix, If I did it again I would go 100 sq ft. especially if you use a light color (I use biege). I did half my floor at the 128 per mix and have some spots that when dry are a bit thin. On the second half i did 110 sq/ft per mix and it covered a lot better.........If you have a light color I think 100 sq/ft per mix would be just right.
all in all I'm very pleased with it and would reccommend it.
mrobins297aaa
south east michigan
jacks seem to be ok as long as your not dragging it in the opposite direction that the wheels want to go.
I don't have any recent pic's, I'll try and post some
