My fab table build
K
kazlx
Tustin, CA
Friction. When you tighten the clamp it wedges in the hole. But if you pull straight up when it's loose, it comes right out.
LG63
Slick. I wonder at what clearance the wedging action won't work. At .623 you've got a nice snug fit.
K
kazlx
Tustin, CA
You can still clamp the **** out if it. I could tighten it enough to bend that tubing wall.
K
kazlx
Tustin, CA
I think the holes were cut at ~0.628. There's probably about a 5 thou fit. I'd imagine the size isn't critical, you'd have to go pretty small before it would pull out. The tight clearance keeps the clamp vertical though.
K
kazlx
Tustin, CA
I'm 32, so I hope I have quite a few years left to use it :) Plus, my wife and I have a little boy on the way.
LCG
GDL :: MX
Subscribing for reference to copycat it "someday"
waggie
Upland, ca
I don't understand what secures the clamps in the holes.
the 5/8" stud is wedged in there once you tighten the clamp.
I don't know why anyone would want to drill and tap that many holes when a normal hole would do if your table is thick enough.
K
kazlx
Tustin, CA
Finally had some time to drag the table out and pull the top to install the cross beams. I will be using these to pull the top flat.
shephd
va
Congrats to your wife and you for expecting your first child.
I hate to be the one to tell you but he will really eat your time! Your due date is a huge deadline to get your **** done. :)
K
kazlx
Tustin, CA
Finally got the top bolted down and leveled out. It's basically 'finished' at this point, however, I still have some things I want to add. I'm planning on getting the CNC running first though because I plan on using it to build the last couple things. I plan on adding air, some clamp and grinder storage, painting it and possible a large drawer under the top.
rust buster
VA
Great build! I'm building one similar and was wondering if you have had any problems with all 4 casters touching the ground and if you though of leveling feet at all? I'm really struggling how to incorporate them yet keep a rock solid over-built table without having to bend down to the floor to level it out by turning an adjuster screw.
K
kazlx
Tustin, CA
Nope. No issues with the casters. I was worried about that too and racked my brain to come up with some trick leveling system but still able to keep it mobile. In the end, I just decided to go with what works. Now that I have it usable, it stays put really well even without locking the casters. I like being able to just move it around. Just today, I used it to unload all the steel for my CNC table out of my truck. It makes a stout dolly :). I think if I had a big garage or shop I would have just put leveling feet. But since I have a tiny garage and too much ****...it has to adapt. I may cut up some brackets for levelers when I get the CNC running just for a fun project and to be able to level it out if I want.
K
kazlx
Tustin, CA
The end of one story and a beginning of another. I sold my fab table the other day after getting what I felt was a more than reasonable offer. I have version 2.0 in the planning stage.
With the way the garage is set up and how I want to do things, the next table is going to be smaller, but expandable and modular. Similar to a Bluco or Siegmund table, but a different flavor. I want a smaller foot print for 90% of my work and to maximize space in my garage, but the ability to expand for larger projects like a gate.
https://scontent-lax1-1.**.fbcdn.net/hphotos-xtf1/v/t1.0-9/10988512_10153416351844168_649000642625248728_n.jpg?oh=6cdde811c2a18990d7d025ba6b2a3621&oe=562EF1C6
Duker
Livingston, TX
Kazlx, looking forward to seeing what you come up with for your new table. :thumbup:
R.Anderson
Wisconsin
Out of curiosity what did ya sell version 1.0 for? and were ya planning on selling it or did someone see your bad *** welding table and just had to have it offering a big wad of cash for it?
K
kazlx
Tustin, CA
I was contemplating building a different type of table...the slat type design instead of a solid top. I put the table up on CL for $1500 and had a guy come the next day ready to load it and we agreed on $1400. I had about $1000 in materials/labor costs in it (not including my labor).
I have been a little tight on space with my CNC plasma table taking up so much room and never quite had enough room to walk around the table. I sold my Deckel mill (which had a tiny table) and replaced with a regular Bridgeport, which needs more operating space. I was always squeezing or trying to move the fab table. The size was nice, but overall, I don't really need the size most of the time. If I had more space, it wouldn't be a big deal. Overall, it was a bunch of little things, along with the fact I can't leave well enough alone, but the driving factor was space, and it was a beast to maneuver for little adjustments. What sealed the deal was I had some ideas about what I wanted to build and found a table that someone had built that was very similar.
K
kazlx
Tustin, CA
Here's the start of 2.0. Just need to figure out how I want to attach the two main beams and then design the framework.
https://scontent-dfw1-1.**.fbcdn.net/hphotos-xtf1/v/t1.0-9/17709_10153419036144168_5552840365037366202_n.jpg?oh=662bc5ae61a93a73a709effd86d3902f&oe=55E93B89
K
kazlx
Tustin, CA
Yea man, I dig seeing all the stuff on IG. I'm heading to Whistler to ride the bike park for 9 days, should be getting started when I get back.
K
kazlx
Tustin, CA
I will be posting to this new thread as I make progress. Will be about two weeks until I get started. I leave on vacation tomorrow to ride some downhill mountain bikes in Whistler for 9 days.
http://www.garagejournal.com/forum/showthread.php?t=295081
As far as the table goes. Nailed down pricing on the plates. Will be using a 4'x8' 1" HRS plate. I will most likely have my supplier section into manageable pieces. Having specific sizes cut out was almost the cost of a whole sheet, with no drops to keep. Having them waterjet out was just stupid expensive.
There is a small chance I will be able to have a buddy machine them for me. He works at a machine shop with a table big enough to take the individual plates. If I can get a good price, I will have him knock them out. If not, I'll be putting in some nights on my Bridgeport.
PhantomEB
Medicine Hat, AB, Canuckistan
Damn they go for that much!
I tempted to sell my little one but nah I don’t want to do all the work again so might as well just open up the holes to 3/4, round off the corners to a 2” radius and semi polish up the top.
