What’s a good leather apron? Something like a Hobart from NTE any good, or are ones like that too thin?
I've switched over to Diablo and Lennox diamond cutting wheels at work cause we grind in some very odd angles. Can't shatter a steel disk with a cordless grinder that I've seen yet
How long do those diamond discs last?
They claim at least 10x as long as a conventional abrasive disc. Enough that the cost of cut is reduced using diamond.
I found that while it is initially very aggressive (more so than the best of my slicer discs), the cut speed slows down rapidly, and for most of its life it cuts more like a cheap slicer disc (kind of frustratingly slow). Still, for the safety and lack of black gook in my lungs, I prefer the steel cutting discs. I haven't tried the borazon grinding wheels yet. They're super pricey.
Have you ever tried dressing the blade? You can "uncover" more/new diamond cutting surface by making a few wet cuts through a dressing stone. At the fire station, we used a few old fire bricks as a substitute. I'm told a cinder block will also work. It kept our 14" rescue saw blades cutting sharp.
Ive had them blow apart a few times. Last one i had to get a few stitches to hold my thumb together since i wasnt wearing gloves. Im alot more careful since then. Ive also had to have crumbs picked out of my eyes multiple times. Ive learned the hard way for every piece of safety gear i now use.
Now if I could just figure out how to stop catching on fire...
Stick with brands that are actually manufacturers, i would not trust even DeWalt, Bosch, Metabo brands as they don't make themselves and goodness knows where they source them from 1 year to the next (they will be sourced cheap thats for sure).
Stick with manufacturers like Walter/Globe , 3M, Pferd, Sait, Tyrolit, Klingspor and you wont go far wrong.
Nope. Local welding stores usually carry them though.Are any of these brands available at the big box stores?
Although, the Pferd cup wheel I bought was a little disappointing. It worked extremely well, just fired a lot of bristles out.
I will say, I just started using Pferd stuff and I am quite impressed. Way better than the DeWalt or Norton stuff at Lowes. The Pferd CC-Grind discs are amazing.
It was a big 4.5" brush, I was running it at ~4,000 RPM on my variable speed grinder. It was rated for 9,000.I find that if i run the small cup brushes at around 8000rpm it makes a massive difference with shedding, does a better job and lasts a lot longer. Most brushes are rated around max 12,000rpm to sell to mass market 4.5" single speed angle grinders, but in reality the optimum rpm is a lot lower. If you do a lot of grinding and brushing a variable speed grinder is a good investment.
Flap wheels are nice, but they in absolutely no way replace a grinding disc. A good grinding wheel will hog out way more material, way faster, for way longer than even the coarse flap wheels. Step into something like a Pferd CC-Grind, and you won't use flap wheels for general grinding use ever again.I have no idea as to why people even use grinding discs as flap discs are superior in every respect and WAY SAFER. My only use for grinding discs are for smoothing out a fillet weld on an interior angle. For that purpose I use a wheel dresser to put a radius on the outside rim of the disc and use the edge of the disc to grind the fillet into a nice curve. Other than this one purpose it's flap discs all the way.
