My first welding project
R
rockcrawler
Dallas, TX
Thanks. It was fun to build. In hindsight, I wish I would have used 14g or thicker, but I was doing it on the cheap.
Kaizen
New England
What size flux core? I only used it on my 110 machine doing heavy stuff so not even sure if they make a .025 but that might help. Maybe tack welds instead of beads as well. each tack overlaps the previous by half.
If you can get good using flux you'll be a master when you get gas and solid going.
Kaizen
New England
Currently using .030
I was using that for 1/8 to 1/4 inch steel. i found flux kind of explodes when arc starts as compared to solid wire is a softer start so no blow through. i've hear guys say they have done whole car restorations with flux so its possible but not the easiest.
R
rockcrawler
Dallas, TX
Thanks for the info, suggestions and encouragement. I’m assuming it is recommended to use a lighter wire for thinner material so that your not laying down so much?
Terra Nova
Looks great! Nicely done.
As mentioned by others, 16gauge it tough enough with solid wire and shielding gas. Just did a bunch of it with 0.030 wire and 75/25 gas. It was tough for certain joints. Really easy to get too much heat into the material and then you're welder settings are too hot.
Been meaning to pick up some 0.023 wire and try that out
Kaizen
New England
Yes a smaller bead but also takes less heat to melt it which should help reduce blow through. As i said tack weld it together then add tacks off of those. Finish with a bead over all of that once you clean the metal again. I use this often on old thin auto body metal.
R
rockcrawler
Dallas, TX
I’ll try that next time. Thank you.
dalepres
Park Hill, OK
I was going to mention getting a machine that uses gas instead of flux-core (guess I just did mention it) but your project looks fantastic.
I've watched a lot of videos on the top welding sites on YouTube and one common thing I've learned is that even the best often use a grinder to make things look good. A grinder covers a lot of errors.
Anyway, nice job!
R
rockcrawler
Dallas, TX
Anyway, nice job!
I’ll have to start looking for a tank soon. My welder (Hobart Handler 140) can use gas or flux.
Copymutt
Colorado
I also tend to fab things out of thinner wall steel. A great source for free metal is the back lot of Tractor Supply. Make acquaintance w/ the manager. They place display old shelves and racks w/ the discarded pallets. Making solar wall frames this weekend. Zero cost for the steel.
R
rockcrawler
Dallas, TX
Nice. Good idea. Thanks.
nadogail
Coronado, CA
My first welding project was a cart to mount my Hobart AC/DC Stickmate Welder on. I used repurposed steel and a short bit of 1" pipe for the handgrip.
